Old 16th December 2008, 10:47 PM   #3131
By definition, X is feedback. You can't build a 0dB feedback circuit and have it be X. That said, there's not a lower limit on X feedback...if you want 1dB feedback, it's yours for the taking. The upper limit is whatever the circuit will stand, in terms of open loop gain and stability.
I've got some admittedly rusty braincells that tell me that the open loop gain of a classic Aleph is somewhere around 40dB. Given that the closed loop gain is around 20dB, the math is simple: A standard Aleph has 20dB of negative feedback. By tube standards, that's high, but by solid state standards, it's low. Given that the open loop gain is limited, you're going to have to either redesign the thing for higher gain or accept lower closed loop gain if you want to increase feedback. If you want to decrease feedback, you can, but keep an eye on distortion, DC offset, and closed loop gain--a 40dB gain amplifier is all but unusable in most systems and the performance will decrease.
Grey
Old 30th January 2009, 06:27 AM   #3132
Patrick
I tested your balanced protect circuit.
But I got wrong result.
CCS 2mA. Supply voltage 24V.
When relay on state, "+in" and "-in" point were 1.4V both.
To trip relay it needs 5.8V over at "+n" or "-in" point.
Plz help...
Old 14th May 2009, 09:46 PM   #3133
RS232 is offline RS232  United Kingdom
Hi everybody
I know this is a old thread but I got hold of 2 18V 300VA trannys and 1 very big heatsink and whant to bild the Aleph X.
Can someone point me to a workable board or to someone that still have some (2) boards for sale.
Ric
Old 15th May 2009, 03:23 AM   #3134
Hello Ric
A good idea is to go down to your local electronic shop and purchase some Universal pre-punched experimenters boards, not much to this amp and is very easy to use these boards, plus is more fun!
Dan
Old 15th May 2009, 03:32 AM   #3135
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by Chois¢â
Patrick
Plz help...
you put -Vcc on gnd or on -24V ?
it must be -24V
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 16th May 2009, 11:02 AM   #3136
hi,
i just found this from here http://www.penguinlovers.net/audio/alephx60_proj.html
I did not use RCA, un-balanced mode as it so unstable in DC offset...... Some warns me "NOT" ever use un-balanced mode in A-X....
is this true?
i've been giving up my AX project since it always distorded badly if i increase the volume.
and yes im using unbalance.. i use 10K attenutor as passive volume.
are there any cure to fix this problem.
thanks
Old 16th May 2009, 11:13 AM   #3137
Zen Mod's Avatar
thanks
it's made for both balanced and unbalanced , with balanced as preferable (full SUSY blahblah)
best way , if you want someone to help you , is to bring :
1. exact schematic you use
2.exact measured voltages in important points
3.some pics of gadget itself
or you can wait a little , as soon I sharpen my bean-looking skills problem will be solved
Old 16th May 2009, 11:37 AM   #3138
right now im using the transformer for something else..
heres the last measurement...
AFAIK it use kristijan schematics of aleph X. with little differences
notice there are lytic caps accros the input.
this is ps schematic, is this possible?
it use 8xIRF240/channel.
quiescent current about 1A. tried lowering to 0.5A but it didnt solve the problem.
thanks for your help
Old 17th May 2009, 10:24 AM   #3139
EUVL is offline EUVL  Europe
> I tested your balanced protect circuit. But I got wrong result. CCS 2mA. Supply voltage 24V.
> Plz help...
Sorry for ridiculously late reply. I have not been watching the AX threads for years.
CCS 2mA is too low. J508 is 2.4mA, giving a max of 4.8V across one of the 2k resistors. This minus 0.6V drop across the 1N4148, and a further 3.3V across the zener, still gives 0.9V to turn the downstream transistor on. This is not the case with 2mA. You can make up for this by changing the 2k resistors (2x) at the collectors of the BC640s to say 2.4k or even 2.7k. The circuit should then functions properly.
To adjust trip point sensitivity, you can vary the values of both 1k resistors at the BC640 emitters (both simultaneously). E.g. when changing 2k to 2.4k, consider using 1.2k instead of 1k.
You might also need to adjust the value of the 150R power resistor to suit your relay. The valus is given by 2.4V / Relay on current. The 2.4V comes from the 3V zener - BD139 Vbe.
Hope it still helps. I have sent you a PM.
My sincere apologies.
Patrick
Old 17th May 2009, 03:13 PM   #3140
ccschua is offline ccschua  Malaysia
hi audioholic,
your picture looks totally familliar from the china website.
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 03:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 11 27th August 2009 03:42 PM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 12:11 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 08:55 AM
Page generated in 0.15243 seconds (77.25% PHP - 22.75% MySQL) with 11 queries
