#2131 |
Thanks for reply,
IRFP044N are twice cheaper then IRFP044. According to the parameters IRFP044N would be use, but what about sonic inflluence?
Jarek |
#2132 |
#2133 |
I think there are other factor that influence the sound more than the the IRFP's you pick. The bias for one. I have used IRFP 064n, IRFP 044n, IRFP 048n, IRFP 140n, IRFP 250, IRFP240, and IRFP 254. They all sound good.
Peter, I you sure they are 8 ohm speakers?
MikeW |
#2134 | |
Bias or not I like voltage, like mosfets |
#2135 | |
Stefano thinks like I do on this one. I think it's better to lower power expectation into lower impedance loads than it is to run out of voltage margin. |
#2136 |
The mosfets with odd suffix number like 150 or 054 or that contain the letter N are not recommended, don't ask me why, I don't remember, there was extensive discussion here months ago.
#2137 |
I don't know why, but I was always under the impression that the rails voltage level dictates the power level, but obviously this is not the case. Does it mean that one can actually choose any power level without caring much about how high are the rails? (I mean here higher rails than required). Why everybody was so much concerned with 12 V rails in the beginning of the thread?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2138 |
Why would Mr. Pass pick a IRFP 044n for the Zen-V4 ?
MikeW |
#2139 | |
you're right! +-12V rails means 72W max on 8R, and 144W max on 4R (with high enouth bias, of course) maybe slightly less, cauz you can never output as much voltage as the poser supply rails, but it's still enough power woth 12V rails |
#2140 | |
I don't see how anything that was said here violates that sacred principle. |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.13458 seconds (74.72% PHP - 25.28% MySQL) with 11 queries |
