Old 20th February 2003, 04:29 PM   #2011
Originally posted by nar
Stephanobilliani,
The VR doesn't seem to vary enough DC offset for me.
Looking at Grey's original schematic,I made a mix from Rtirion and
V2 is now 250 ohms
R26 is 470 ohms
R24 is 221 ohms
What are the values you use for those resistors ? Thanks.And which is your latitude for offset ( VR at max,DC offset and VR at min,DC offset ? )
Maybe I can't vary bias diff.pair enough
Which is your value for the Magical Resistors ?
In your version,how many power mosfets ( i.e P240 ) do you use for the whole amp ? ( I don't think about the 9610s )
Great thanks for reply.
The need for changin imput to ground rsistors (R19 R29) from 10k to 68k was the first thing when I tested the circuit, as the absolute dc wasn't good .I say 15 or so volts.
The resistors from the output to the sources of the diff pair are 4.7k and for me is hard taming the dc offset varing this ones .
I notice large variations of dc as you report , changin this resistors.
VR2 give large variations also but the position depends by the current trough the output mosfets.
For me R24 is 475, VR2 220, R26 330.4 mosfets/channel R5 R6 etc. 0.33 ohm.
Setting VR1 and VR3 for the max current VR2 voltages variations are from -11 to + 5 volts.
Rails : +/- 15 volts
Stefano
Old 20th February 2003, 06:15 PM   #2012
nar is offline nar
nar's Avatar
Ok,so I changed a lot of stuff.
I went to 2k2 for the famous magical resistors.
I got 475 ohms for R24,332 ohms for R26 and a 200 ohms trimmer,like in Grey's version.
I re-ran the circuit,and this time I can adjust absolute DC to 0V !
But varies + and -,I have to wait for temperature equilibrium for
precise 0V.Around 0V,the offset goes - 30mV and then to +30mV,and again.
My bias is now a little over 4 A. Sink temperature is OK.
I have to wait 2 hours.Listening !
What a pleasure
Thanks Staphanobilliani !!!
PS:The draw of the Aleph Current Sources seems higher than the output stages.In other terms,more draw on V+ than on V-.I have no explaination.The values for R 39 and R 35 are 221 and 100 ohms respectively...
If the to92 NPN for output stage sense was limiting current...I have no clue yet however.
"... Audio needs the thinnest wire ..." Rowan McCombe
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
Old 21st February 2003, 05:51 PM   #2013
joke is offline joke  Croatia
joke's Avatar
Can some one please tell me what capacitors voltage I should use for C1,C3,C5,C6 - 220uF...will 6.3V be enough...
I was thinking to use BG 220uF/6.3V NX tipe...
Josip
Old 21st February 2003, 06:04 PM   #2014
grataku is offline grataku  United States
joke,
I used 220uF, 35V panasonic FC in my prototype. They fit the ver1.0 pad spacings
Old 21st February 2003, 06:08 PM   #2015
wuffwaff's Avatar
Nar,
how do you know there´s more current through the current sources? If there´s less through the output stages then where is that current gone? I mean it can´t dissappear can it
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 21st February 2003, 10:12 PM   #2016
Account Disabled
Originally posted by joke
220uF/6.3V
For C1 and C6, 220uF/6.3V okay.
But, for C3 and C5, I recommend minimum 12V rating.
JH
Old 22nd February 2003, 06:14 AM   #2017
swede is offline swede  Switzerland
swede's Avatar
Default I mean it can´t dissappear can it
wuffwaff: ;=) Nope, in that case mr Kirchoff would be turning in his grave...
//magnus
Old 26th February 2003, 01:19 PM   #2018
nar is offline nar
nar's Avatar
Default AC current gain adjust in Aleph X
Hi everyone,
Could someone give me the recipe to adjust the AC current source gain to 50 % ???
I have a BF generator non balanced out,and a good multimeter but non True-RMS type.I have no scope
But I guess it must be simple to adjust when having clear explanations
Thanks for feedback
Anael
Old 26th February 2003, 01:45 PM   #2019
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Some info is here: http://www.diyaudio.com/forums/showt...887#post133887
There was also an old thread where everything was nicely explained. You might try to search it or I will find it in a meantime.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th February 2003, 02:00 PM   #2020
UrSv is offline UrSv  Sweden
UrSv's Avatar
Default Re: AC current gain adjust in Aleph X
Hi everyone,
Thanks for feedback
Anael
Been covered in several threads but essentially I think you could do this:
Disconnect R10 (or whatever the resistor is called that feeds back to the current source). Run a signal into the amp driving a constant load and measure the voltage variations on the source resistors of the output stage. Now connect R10 (...) and adjust until that variation is half of the original value. Then the contribution from the current source is half.
UrSv
Those who say it can't be done should not stop those who are doing it.
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.15267 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
