#101 | |
Ok, I first finish my Aleph 2 hopefully this week, and then I will build the Aleph X... Edwin |
#102 |
Account Disabled
hello
i would realy like to build aleph X but i dont know how to calculate the output power with diferent supply volteges and bias currents. can you hellp me. janey |
#103 |
Hi everybody, i am getting nervous fingers watching this nice X-aleph cicuit, thank you GRollins.
I want to make one but im busy making several Pearls for my friends. I made one for me and its sounds so beautiful that everyone wants to have one too! I use an alephL and a Aleph 3 upgraded with an aleph 30 output stage. I started building Zen and Bride of Zen some years ago and made several different version of them allways trying to improve the sound. After a while i just had to build the alephs to get further and i really love their sound, warm and liquid with rythm and color. The aleph 30 sounds cleaner and has the real kick bass that the aleph 3 was missing. Thank you Mr Pass for your idealism and your generous support!! Your help rescued my ears... The idea that my alephs could be improved with x-aleph makes me dreaming.... But then i have to build a x preamp too! Has someone thougth of it? I am thinking of a to stage design with a toshiba 2sk389 in the input differencial stage. It should be an easier task with the great work from GRollins. |
#104 |
janey,
I haven't forgotten you. Be patient. There are a number of posts I need to answer, but I've been kinda preoccupied with things like having the sheriff come out and run some bad guys off of my property, in addition to the usual Stuff and Things. UPS still hasn't delivered the 48 hour days I requested long years ago. oliverniekamp, I've got a preamp in the works...or you are welcome to roll your own. The one I'm doing will incorporate another strategy (not NFB) to combat distortion in addition to the X topology. all, I have been in communication with Nelson about the cap across the NPN question. He says that oscillation can happen, but apparently it isn't a given. I'd like to ask rtirion and others who are simulating to try alternate parts during the course of their workups. As far as I know, Nelson is using Zetex NPNs in his commercial product. I am using Motorola (aka OnSemi) MPSA18s in mine. I have used both IRF644 and IRFP044 output devices in this circuit with no problems, but sure as rain falls down, someone's going to stick in a part from Harris, Toshiba, or Motorola and end up stubbing their toe if that's the critical part. Parts substitution is a way of life for the DIY community. For that matter, go ahead and try other IRF parts. Someone asked about the IRFP244 earlier, I believe. I'd like some help nailing down the parameters that can make this thing oscillate. Oh, and another thing--just for fun, someone hang another couple of pairs of outputs out to the sides. See if cumulative Gate capacitance is an issue. I'd be happy to try that one here in real life, but my power supply isn't big enough to handle the load. I'd also like to request that those who are set up for it perform a Monte Carlo analysis to further define the stability region. Thanks. I believe I will go ahead without the cap, but will try to make room for it on the PCB. Once all this is on a board, the environment will change and it may break into oscillation once deprived of whatever stray capacitance I've got on these push boards. If I can get by without it, I probably will, but others may need to be aware of it. In my case the load is purely resistive, albeit low (about 2.5 ohms), so I don't anticipate any difficulties in operation. Grey |
#105 |
Banned
"I have been in communication with Nelson about the cap across the NPN question. He says that oscillation can happen, but apparently it isn't a given. "
"Oh, and another thing--just for fun, someone hang another couple of pairs of outputs out to the sides. See if cumulative Gate capacitance is an issue. I'd be happy to try that one here in real life, but my power supply isn't big enough to handle the load. I'd also like to request that those who are set up for it perform a Monte Carlo analysis to further define the stability region. Thanks. " These were the only points that I so poorly was trying to make before all the diversions sidetracked everyone. Thanks for you exploration into this issue. I believe everyone will benefit from the knowlege and be able to apply it to not only this design but many others. Respectfully, H.H. |
#106 | |
#107 |
Is that bug dead or alive?
#108 |
I should finish the main circuit today. It's not really complicated. I'm looking at 20V rails and 3 pairs of devices per side. You can see a better picture at: The beaty of p2p wiring
#109 |
Jam,
I don't anticipate any real problems in scaling this thing up. Steve, Nope. Not holding anything back. Still only one channel. Don't have a clue what I'm going to do for heatsinks. Haven't even gotten in my Caddock resistors yet. Still got 5W ceramic resistors in the circuit. janey, Okay, hold on to your hat. This is Uncle Bear's rule-of-thumb recipe for building an Aleph: Step One-- Choose a target RMS wattage into your speaker. Remember that most speakers have peaks and troughs in their impedance curve, depending on frequency. Plan accordingly. Leave a little elbow room. Step Two-- Determine what that wattage/speaker impedance works out to be in terms of voltage and current. Step Three/a-- If you're building a normal Aleph like the original product line, multiply the voltage from Step Two by 1.6. This is your DC rail voltage. Put a + and - in front of it, and you're in business. Step Three/b-- If you're building a bridged Aleph like the XA200, multiply the voltage from Step Two by .8. Step Four/a-- If you're building a normal Aleph, divide your current from Step Two by two. This is your total bias current. Step Four/b-- If you're building a bridged Aleph, multiply your current from Step Two by two. This is your total bias current for both sides of the amp. That will get you in the neighborhood. Everything else boils down to keeping the power dissipation down to reasonable levels on the output devices, and adjusting the resistors accordingly. G'night folks...gotta charge my batteries... Grey |
#110 |
Account Disabled
thanks Grey for your response.
so if i want 60w and drive 4 ohm load i need 12.4 V supply rail and 7.75 A bias current. the total disipation will be 196 W and for this i need eight power transistors (24.5W each) or maybe 12 power transistors (16.3 W each). is my calculations right? and here is one more question. how to recalculate the source resistors? sorry for so much questions. janey |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 03:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 04:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 11 | 27th August 2009 03:42 PM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 12:11 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 08:55 AM |
| Page generated in 0.16733 seconds (80.57% PHP - 19.43% MySQL) with 11 queries |
