Old 5th November 2002, 02:26 PM   #1011
Koy is offline Koy  Czech Republic
AX has symetric input. Most of players are euiped by asymetric output. Do you use any symetrising circuit for AX?
Old 5th November 2002, 04:24 PM   #1012
grataku is offline grataku  United States
Koy
plan to use BOSOZ, straight up no CCS. Best sounding preamp I ever built.
I expect the pair will sing like a hummingbird.
Pass creations are extraordinary.
Old 5th November 2002, 04:43 PM   #1013
Brian
if you have a linux machine in the lab you could use
http://bach.ece.jhu.edu/~haceaton/pcb/
I have heard good things about it.
Old 5th November 2002, 07:53 PM   #1014
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
Default sound of aleph x?
Didn't someone post a comparison with the Zen a few pages back? Carpenter, I think...
- Chad.
Old 5th November 2002, 07:56 PM   #1015
hifiZen's Avatar
Here we go...
http://www.diyaudio.com/forums/showt...7186#post77186
- Chad.
Old 5th November 2002, 08:53 PM   #1016
Faber is offline Faber  Italy
Send a message via ICQ to Faber Send a message via MSN to Faber
Default ...and that's my own PCB
This is my own PCB for Aleph-X :-)
That's my first Aleph design and also my first double-sided pcb design, I hope there are no mistakes in it.
To have traces and layout simmetrical, I will mount the Mosfets vertical on the PCB, they will be coupled with a screw to an alluminium angular attached to the heatsink.
Tell me what you think about.
This is the first side
Bye, Fabrizio
Old 5th November 2002, 09:00 PM   #1017
and this is the second side.
bye1
Fabrizio
Fabrizio
Old 5th November 2002, 09:13 PM   #1018
Looks pretty good. I think you can safely get rid of the fuses there is no point in having them in SE class A. You would be putting a 10-15 Amp fuse that would blow when the house is on fire, maybe. Could use the extra room for the input caps.
Old 5th November 2002, 09:38 PM   #1019
nar is offline nar
nar's Avatar
Hi to everybody.This is my proposal for an AlephX layout.It is close as the one I will realise by hand.Note that the unit square on my drawing is 5 mm and not 5.08 . This is because I have only normal paper.However,the final layout will be 5.08 space standard.
I have a few jumpers.I don't consider it badly,I just get rid of longer connections that way.The board is single sided,and the total layout is quite small anyway.It is also easyier to replicate than double-sided boards.
I intend to go with a total of 8 power devices.This choice is dictated by the fact I have hundred of IRFP240 in stock.Each device is intended to run at slightly more than 1 Amp bias on +/-22V power supply.I think it is right about safety power dissipation margin.Oh,I have included the Magical resistors from output nodes to sources of the differential.And I tried to go for most symmetric possible layout.
Any feedback welcome,as it is not realized yet.I am in no hurry.all thanks goes of course to tvi ,for inspiration.
Best regards to you all
Anael
PS.Warning.The board is not tested.But I guess I have no mistakes in it
"... Audio needs the thinnest wire ..." Rowan McCombe
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
Old 5th November 2002, 10:47 PM   #1020
The one and only
Nelson Pass's Avatar
These layouts are extremely good, particularly Fabrizio's
(Love that name).
But I want to point out something, which is that while
they are symmetric geometrically, they will still tend to
pick up stray magnetic field. Not much, but some.
Of course you can keep them away from transformers, which
I recommend anyway.
For the ultimate, though, we want to take this symmetric
layout and fold it at the middle, so that each half experiences
the same magnetic field.
For the XA200 and XA160 so far, I have intermingled the
placement of each half to achieve much the same thing -
we want the symmetric halves to experience exactly the
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 03:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 11 27th August 2009 03:42 PM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 12:11 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 08:55 AM
Page generated in 0.14643 seconds (75.31% PHP - 24.69% MySQL) with 11 queries
