hi to all
i intent to built an ALEPH, but i cant decide which one to built :ALEPH 2 or ALEPH 4 ? My speakers have the below characteristics: 1) 6 OHM 2) 92 db/1w/1m 3) rated at about 300w i have two transformers rated at 1500 VA 235VAC primary 2X43VAC secondary. Waiting for any suggestions. |
#2 |
6 ohm nominal? More important is what is the minimal impedance and also the phase shifts. Is the 2 not better in driving difficult loads?
Is that all there is? |
#3 | |
i thought so, thats why im doing the aleph2 for my 4 ohm nominal (1 ohm minimum) speakers.
Nelson always says that the Aleph2 is HIS favorite. Quote:
#4 |
With 1 ohm minimum I would make an Aleph 1 or maybe a very high biased Aleph-X.
Or make other speakers
#5 |
well, im doing an aleph2 and aleph3 for each speaker, with active crossovers. so, it should be fine.
they are planars, so they have a pretty easy load, its just low resistance and low efficiency. so they need stable power. aleph-x's dont work well with my speakers from what i understand. i didnt think they liked low loads. i know they are stable, but i need the power doubling too. to get the power i need, it would be HUGE and heat the house. |
#6 |
Let me guess, Apogee?
#7 |
nope, magnepan.
apogees have nominal impedences of 1 or 2 ohms and can dip into fractions. |
#8 |
Hi nikosgr
I have KEFs 108.2 with 4 ohm nominal impedance and 92dB my Aleph 4s are singing like a birds. Fill free to ask any question as I am more than fine with Aleph 4 (monoblocks) Here is the link Yet another Aleph 4 Trigon |
#9 |
Hi All
thanks for the replies. Here is a picture of my living-room that is not acoustically treated (WAF FACTOR!!!!!!!!!!!!!)35 square meters the speakers minimum resistance is about 4 OHM trigon hi i have seen your work EXCELENT!!!!!!!!!! AND VERY INSPIRING my amp is an old musical fidelity P-270/2 it has been upgraded i believe that constructing an aleph will scale up the sonic performance of my setup but still i am confused in terms of current output and power which one will have more efficient control over the speakers ?????? |
#10 |
the amp
| OB or TL - Help me decide | jim rose | Full Range | 13 | 22nd March 2007 09:10 AM |
| Please Help!!! me decide on a chipamp | Morning_Star | Chip Amps | 4 | 14th September 2006 02:59 PM |
| Help me decide on an OP-amp | Cradle22 | Parts | 16 | 25th April 2005 04:31 PM |
| Aleph - Can You Give Me A Hand To Decide Wich One To Build? | b_online | Pass Labs | 5 | 10th May 2003 03:22 AM |
| Page generated in 0.11125 seconds (81.01% PHP - 18.99% MySQL) with 11 queries |
