Shielded or Not, that is the question.
Old 30th June 2004, 11:37 AM   #1
kilowattski is offline kilowattski  United States
kilowattski's Avatar
Default Shielded or Not, that is the question.
Pardon this dumb question but when building my aleph P 1.7 I am at the wiring stage. I was going to use shielded cable from the input and output connectors to the board. Is this really necessary, can I use unshielded wire? I searched the forum and can't find anything.
Kilowattski
Old 30th June 2004, 01:06 PM   #2
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
I used unshielded cable inside my X-BOSOZ and have no problems whatsoever.
Even the short pieces of wire to the ONO boards input are unshielded.
The only thing I did do is to remove the power supply into a seperate case.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 30th June 2004, 02:04 PM   #3
jh6you is offline jh6you
Account Disabled
Me.Myself.I:
saw inside of many expensive pre amps from the Japanese Stereo Sound magazine. All of them I saw had unshielded wires and unshielded PCBs.
My BOSOZ also has unshielded p2p wires all the way even with the transformer inside the same box.
Old 30th June 2004, 03:02 PM   #4
Djomil is offline Djomil  Serbia
I have also used unshielded cable in my BZLS and it works very quiet.
Greetings from Belgrade
Old 1st July 2004, 02:44 AM   #5
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It works particularly well if you twist the outgoing and
return paths.
Old 1st July 2004, 04:13 AM   #6
Well I guess it is unanimous. Unshielded it will be. Thank you all for responding. Oh, and twisted it will be, Nelson.
Kilowattski
Old 1st July 2004, 04:20 AM   #7
GRollins is offline GRollins  United States
Twisting the signal and ground leads together keeps the two in close proximity, thus allowing the ground to shield the signal fairly efficiently. In principle, you can accomplish the same thing with the wires side-by-side (think Nordost). The trick then is to keep them together. I've always meant to try some of that flat computer ribbon wire with alternating signal and ground, or better yet, three wires in a ground-signal-ground configuration. Never get around to doing so.
Grey
Shielded or Not, that is the question.Hide this!Advertise here!
Shielded Enclosure vs. Not ZenCow Chip Amps 3 18th May 2008 08:01 PM
shielded vs. non-shielded mytool4u Instruments and Amps 12 7th July 2005 10:12 PM
Shielded Wiring ble0t Parts 4 11th August 2004 05:34 AM
Shielded woofers jswen Multi-Way 1 5th May 2004 09:02 PM
Shielded Tweeters Won Multi-Way 0 14th February 2002 03:58 PM
Copyright ©1999-2017 diyAudio
