Other IRF-MOSFETS
Other IRF-MOSFETS
Old 25th June 2004, 08:41 AM   #1
ljozsef is offline ljozsef  Hungary
Default Other IRF-MOSFETS
Hallo experts, please Mr. Pass,
What about the range of the yet not mentioned IRF-FETs?
There are some web offers with IRFP 460, 3710, IRFZ 44 etc. What would decide if they were champions or audio garbage?
Why do we see the 04x, 14x and 24x only? - please forget their price this time.
Are there some limits regarding Ciss, Rdson or other parameters? In my particular case, the A-X would be the basic topology, with single output FETs.
I think your help would be of general interest.
Looking forward to your quick kind answers,
Laci
Old 25th June 2004, 08:57 AM   #2
uli is offline uli  Austria
Default differences
Hi Laci,
Normally the IR Mosfets are switches. When you "abuse" them
for linear purposes not all of them are well suited. From long
year experience the bigger the 2nd number, the less suited
is the device. EG 044 is much better (sonically) than 064.
There are many reasons for that e.g. gate-source capacity which
depends heavily on the number of parallel devices on the dye,
If you look at old NP designs (A75) he used 230. As they are
out of production you better use the devices with the lowest
number possible (mostly 140, 240, 9140, 9240).
There are even "rumours" that higher voltage devices such as
240 work better than 140 or even 044, but I personnally have
no proof of that.
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 25th June 2004, 09:20 AM   #3
Default Hi, Uli!
That would mean, under my items IRFZ44 could be considered, while 460 were worse and 3710 the worst (?).
Regarding Cgs, its absolut value cannot be so critical considering the original Pass projects with a palmful of paralleled devices (4-6 x Cgs), more its nonlinearity.
BTW, in that case is the bandwidth the same because of the also paralleled series gate resistors or having the same driver will be altered?
Laci
Old 25th June 2004, 09:36 AM   #4
Default Re: Hi, Uli!
Laci
As every fet forms its own lopass pole (Rg +Cgs) it depends
on Cgs too. Driving a huge capacity through Rgs needs a lot
of "overshoot" in the driver and a lot of current too. This in
turn leads to the need of more bias in the driver and more
nonlinearity between driver and output which has to be
corrected by global feedback and can cause distortion through
overload of the driver (SIM).
Uli
Old 25th June 2004, 10:04 AM   #5
Upupa Epops is offline Upupa Epops  Czech Republic
Modern vertical fets have " internal Rg " only a several ohms, which is insignificant against typical resistor connected in series with gate electrode ( 100 - 500 ohms ) .
Old 25th June 2004, 10:42 AM   #6
Default Series Rg
Yes, I was referring to those external resistors; I think so was Uli's answer, too.
Now, apparently all being paralleled, the resulting pole will be at the first look the same. Is this the reality? I am disposed to believe that the bandwidth will be compressed.
But --- ?
Laci
Old 25th June 2004, 12:28 PM   #7
Default Rg + Cgs
The higher Cgs the lower Rg should be to achieve the same
pole frequency. As impedance level drops the amount of
transient current to drive that pole rises. Having such poles
in the NFB loop leads to SIM simply because those transients
saturate the driver stage without contributing anything to
open loop gain. Try it, you will hear the difference!
Uli
Edit: not to forget that a low Rg can lead to severe oszillation
as the source impedance of the driverstage drops too low!
Old 25th June 2004, 01:28 PM   #8
I was build first mosfet amp twenty years ago. Do you mean, that my experiences are not sufficient ?
Old 25th June 2004, 01:45 PM   #9
Default Try it, you will hear the difference!
I would be happy to listen to differences, but also very pleased to be able to choose a proved set of MOSFETs...
Regarding the serial gate resistor, I did not mention dropping its own value, only the resulting parallel resistance in case of a "battery" of devices.
All told,
1. searching AUDIO at the irf.com were not the best solution (interesting results...),
more important
2. to prefere datasheets with low Ciss (IR-notation) and low voltages (?) and Rds (?). Or these letter not so cardinal?
Laci
Old 25th June 2004, 01:52 PM   #10
Default Upupa Epops!
What do you mean?
I feel nobady was withsaying your post; I definitely not...
Laci
Other IRF-MOSFETSHide this!Advertise here!
Where to buy MOSFETs? goodas Solid State 28 16th May 2014 02:40 AM
What mosfets to use? seafire Solid State 18 25th March 2009 10:44 AM
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 06:01 AM
Why no MOSFETs? Pbassred Solid State 25 1st February 2004 09:06 PM
hmm.. help with mosfets Colt45 Solid State 5 27th August 2002 08:08 AM
Copyright ©1999-2017 diyAudio
