The amp needs to idle at about 2 amps per channel, and if you
figure that a 1 volt loss is OK, then you are looking at .47 ohms.
However it will be running at 2 watts, so it's probably better to
parallel 2 x 1 ohm resistors at 3 watts each. This should work
just Jake, as we say in Foresthill.
