I am able to get some 2nd hand transformers that would give me 36vac--0--36vac.....maybe around +/- 46vdc??
Is that going to be to high when using irfp044s in an aleph x?? |
#2 |
The one and only
Without a load this will come out about +/- 50V. With a load
it will be less, but how much depends on the hardware. This is high, even for an Aleph X. How big are they (VA rating) and do they have 240 V primaries? for that matter, what is your voltage? |
#3 |
Mains Voltage here is ~240VAC.
There are several avaible, D55-449M Fuji Electric Co Ltd, 3.55KVA for $120 each. The primary is 240vac with several tappings. The lowest possable sec voltage is a taped 36vac, I was thinking of using two transformers, one for each rail. I am guessing the highest possable sec voltage is probably no more than 40vac, possably still too low to give me much power. They only weigh 19kg, is that a bad thing? |
#4 |
Go ahead with those monsters
Only thing to be aware of: Buy enough aluminium Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#5 |
Large second hand 3550 VA trafo that only weigh 19 kg
HHUMMMMMMMMM (50 hz)...
Is that all there is? |
#6 |
I think, they will be ok since they won´t be loaded that much
Uli
#7 |
Supposing the hum wasnt too bad, the irfp044 being a 60volt device, and the rails being +/- ~48V ......am I going to cook my 044's?
#8 | |
Since these transformers are 120.00 each, why not contact a winder about getting a pair that give you 25 volt outputs. 240.00 should buy what you need, just not in a 3.5kVA unit. George |
#9 |
So whats the highest safest voltage I can run these parts..maybe 1/3 of their stated voltage ratings? maybe a half? why cant I run them at their full 60 volts?
#10 |
Hi Svetlana,
you could parallel two 40 volt windings and use them as plus minus 20 volt rails and just ground the centre where they meet. I think you need resistors in series to ground though to keep the rails the same? With 6 amps bias that should give abut 120watts class A and dissipate close to 300 watts per channel BTW are there any more of these, im slowly getting bits together for my aleph-X. A company name or phone number of who is selling these would be nice cheers arthur |
| modern day rail voltages | Clipped | Car Audio | 3 | 28th September 2007 04:38 AM |
| Rail voltages from 15-0-15 volt transformer | Bama Slamma | Power Supplies | 3 | 26th November 2006 10:27 AM |
| the best transformer rail voltages for gainclone? | araven | Chip Amps | 2 | 30th September 2006 10:31 PM |
| bosoz rail voltages | EANDERS | Pass Labs | 2 | 25th March 2005 04:19 PM |
| Amp supply rail voltages.... | Xicarius | Everything Else | 2 | 4th August 2004 12:38 AM |
| Page generated in 0.11420 seconds (80.30% PHP - 19.70% MySQL) with 10 queries |
