#11 |
The one and only
It may be that the bump isn't all that huge. Try it.
#12 |
Wow. I will...
m. |
#13 | |
#14 | |
I have absolute offset problems anyway. When cold, I have to readjust because the current regulation doesn't make it (gives 2.5A instead of 3.2 and the amp begins to hum after a few seconds). Anybody knows what's wrong and can help? martin |
#15 |
I tried the simulated low power mode by changing R19 (221k) down to even 10 k but no decrease in bias current
Simulations show that under 20k a significant lowe bias current Anyone with the same experience ? Another option I consider is to use a 2R resistor (R40-42) for the current source and a switch for a high power mode Just one the current source resistor with the feedback to Q5 Anyone tried this ? So far I like Aleph 5 a lot but sound is not any better than the 2 FET model (of Aleph 5) I built with my own PCB design Thanks Adrie |
#16 |
The one and only
I have lowered the bias current in standby by increasing the
positive current flow into the NPN base junction on Alephs and have not experienced anywhere near this much offset, so I suspect you have other issues. If the (-) input is capacitively coupled as with the stock unit, this offset will be minimized, but only by about 6 dB. |
#17 |
I've reduced R19 (221k) in the Alpeh 5 design to get the bias current down for low power operation.
The idea is to use this for normal usage like radio So in this mode the heatsink will stay cool and no unnecessary power consumption. I changed R19 down even to 20k without any DC offeset problems The bias current per FET is then about 160 mA Power consumption is now about 70 watt in low power mode with dual 30V power supply The difference in quality seems to be fairly small, based upon about 6 CD tracks of listening I will use a switch to swicth between the 2 modes of operation Haven't made a decision yet which value I use for low power operation. I will probably go for 250 mA per FET. |
| Standby mode for Aleph series... | eclam | Pass Labs | 10 | 2nd April 2012 11:23 PM |
| Stuck in standby mode | jmillerdoc | Solid State | 3 | 8th March 2010 06:45 PM |
| UC3846 current mode control vs. SG3525 with average current mode control | mflorin | Power Supplies | 32 | 4th November 2009 04:43 PM |
| Aleph-x standby mode | yup | Pass Labs | 16 | 19th January 2007 01:59 AM |
| Aleph-X standby mode (once again...) | CheffDeGaar | Pass Labs | 3 | 3rd September 2003 07:03 PM |
| Page generated in 0.10855 seconds (76.07% PHP - 23.93% MySQL) with 10 queries |
