The one and only
Just when you thought it was safe to go back to the work bench....
Here's 7 easy pieces for chip amps. www.passlabs.com/np/GC-VAR-INV-FDBK-1a.pdf You might find this a trivial circuit, but for those who don't know it, it can be very important. Chip amplifiers have enormous amounts of open loop gain (120 dB = 1,000,000) which can create stability problems when the circuit is set for low gain, say only 10 or 20 dB. This circuit places a resistor to ground at the negative input, which throws away some of the open loop gain, resulting in less feedback. In fact you can put a variable resistor here, and tune the amount of feedback to taste. www.passlabs.com/np/GC-VAR-BAL-FDBK-1a.pdf Does the same thing for a balanced input circuit. Generally you want the pots at equal value, but for the most perfect common mode input rejection, separate pots allow trimming. www.passlabs.com/np/GC-OUTPUT-BIAS-1a.pdf You say your chip amp needs more output bias? Here's an old trick. www.passlabs.com/np/GC-OUTPUT-BIAS-2a.pdf Here we see the same thing as GC-SS-3a, but without the SuperSymmetry jazz, just a pair of chip amps. The voltage sources will be low values, as will the output resistors, and additional output stage is provided by the DC difference in the output voltages across those output resistors. The load output sees the split value, so there's no DC seen there. You also get the advantage of delivering about twice the current as a single chip amp. www.passlabs.com/np/GC-BOOTSTRAP-1a.pdf What? You want your chip amp to behave as if it's seeing a higher impedance and also deliver more current? You can parallel chip amps equally, or you can set one up as a current bootstrap, relieving the load on the first amp, but also leaving it in control of the signal. Sort of like power steering. Watch how you set the current gain of the bootstrap. For this circuit, 50% is a good number. www.passlabs.com/np/GC-BOOTSTRAP-2a.pdf And of course you can go crazy and use a lot of them. In this case, the current gain would probably want to be set to divide the current equally between all the amps, including the first one. In the case of 4 bootstrap amps, each would probably want to be set at delivering 20% of the output current. www.passlabs.com/np/GC-ZEN-ALEPH-1a.pdf How can we resist not making a Zen amp with such a current source? Here we see that the Aleph current source is easily duplicated by a chip amp. |
#2 |
Hihihi, dont shock people late in the evening!
Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#3 |
Very nice examples. These will keep me busy for quite some time.
#4 |
same here
#5 |
diyAudio Moderator Emeritus
"You want me to hold the chip amp where?"
Rodd Yamashita |
#6 |
Anybody got a spice model for an appropriate opamp to simulate with?
Think I need a cup of tea. Jens - already thinking a pot might be better |
#8 | |
In the last 24 hours my head has chipped spun inverted and in true Pass fashion finished in a state of Zen ![]() I'm sure I hurt something in there but what a ride ![]() Thanks Nelson!
#9 |
The one and only
My pleasure.
#10 |
Ok Nelson, i have to ask this, exactly how much time did you spend on those schematics? I knowing you, probably didn't take you long, but I'm curious
-Matthew K. Olson |
| Missing links for 7 Easy Pieces | antomas | Pass Labs | 10 | 29th January 2009 10:48 PM |
| WTB - 16 pieces of TDA1541A | ErikdeBest | Swap Meet | 2 | 2nd June 2006 12:50 PM |
| FS: Tubes--84 pieces, NOS | gengis | Swap Meet | 0 | 9th January 2006 02:27 AM |
| WTB: Three pieces of MC74VHX74 | hifi | Swap Meet | 1 | 31st August 2003 09:51 PM |
| Page generated in 0.11813 seconds (78.16% PHP - 21.84% MySQL) with 11 queries |
