I was just wondering if anybody had any opinions on the two versions of the Aleph L found in http://www.passlabs.com/pdf/aleph/al_serv_man.pdf The Aleph L Rev 1.2 is a very interesting circuit. But no one has built one yet most likely because it needs a stepped pot. Does anyone know what inspired the new topology and what the sonic differences are to the older always active version?
#2 |
A lot of people seam to be reading this post, yet nobody has an opinion. Maybe it would help if I posted small pics right out of the PDF to inspirer people to have a look.
#3 |
this is the 1.2 version
#4 | |
Hi LBHajdu, As it is common knowledge NP is a follower to Albert Einstein "As simple as possible....." You simply don´t need active circuitry at a gain below zero. Therefore not even one active (polecreating) device is in the signal path anymore! Something that isn´t there cannot colour the sound! Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#5 |
Well there may be nothing in the signal path, however the gate of the first input mosfet will load it with a little capacitants. Some source outputs don’t have the current to run passive. I wonder why this design was never used in any other pre-amps opting instead for always active circuits. I can,t even tell if its really passive below the 6th to last contact.
#6 |
In fact many sources are not capable of being run passive.
I think this design wants to be "best of both worlds". If its really passive or not, is a philosophical question similar to "is Aleph really SE or not?" Uli
#7 | |
I built both versions some 2 years ago.
As I remember I liked first version (all time active) much better. And indeed Aleph L is excellent preamp , especially considering number of parts used.Aleph P 1.7 sounds better still but I can see it is pretty much balanced version of Aleph L with added negative CCS. Quote:
There might be enough gain but there are other factors that make passive attenuators sound worst than good active circuit. Bartek |
#8 |
I agree with zygibajt.
I have built both versions of Aleph L and I think the original version sounds livelier, more dynamic with more control in LF and with more presence in the midband. The only "drawback" is that it is phase inverting at the output but then I don't think it is actually a drawback. Nick
Is this phase one of Lumpy Gravy? |
#9 |
Normally a pre should not "sound" at all.
The reason why passive preamps tend to sound not as "lively" as active ones is either the lack of coloration or just poor quality of the source equipment. In most cases the source is not capable of driving passive circuitry and a powerstage. Again I think this is a matter of philosophy, having lowest possible number of gain devices in the signal path or not. Uli
#10 |
I must disagree Uli.
You are 10 times wiser in audio electronic and I admire your knowledge. But in my expirence (tried many passive and active) active in 99% cases sounds better.And the only thing it looses with passive is a little liveness.Passive are always a bit lively and a tiny bit more natural.But they lack dynamic ,soundstageing and bass performance are very poor,and highs are dirty. Less is better to some degree,but too less is not good. Simple circuit like Zen or Son of Zen will never match more complex Aleph X or regular Aleph. It's like with full range drivers.They are simple and in some aspect very very good,but if one is expecting a truly full range outstanding performance from top to bottom, there is no place for such simple solution like full range driver. I think it is mostly impedance mismatch.The passive will never deliver such low output impedance as good active. Bartek |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.10479 seconds (81.77% PHP - 18.23% MySQL) with 11 queries |
