#791 |
Do you mean adapter PCBs (SMD to TH) from the BF862 preamp thread ?
If so, yes I have a couple more. |
#792 |
After looking at the thread again, I think i can make the bf862 boards myself. Am i correct in thinking that you use the version with the BF862 buffer, driven by your bf862 preamp?
#793 | ||
![]() Quote:
#794 |
THis is very similar to the F5, correct. The oonly difference i see is tha you have dropped the protection circuit and the feedback circuit on the front end is different. I understand why you have droppped the protection circuit, since you know enough to not have to worry with them. I don't know that I see an advantage to the different feeback setup on the front end, but I may be missing something. Also, you have dropped the thermistors, which Pass says help with drift. Other than the different fets, am I missing something.
#796 |
I have been known to do that.
#797 |
I have boards for two F4 amps and was wandering if it possible to drive them with just opa1632. From datasheet it appears that its output voltage will swing to within 4-5V of the rails, so 15V rails should yield 20V swing, correct.
#798 |
According to it's datasheet specification OPA1632 swings to within (V-)+1.9V and (V+)-1.9V, respectively, when loaded by 2kOhm. Into 600Ohm this drops to 4.5V within the supply voltage levels.
For a +/-15V supply this would yeld +/-13.1V into 2kOhm and +/-10.5V into 600Ohm. That's 21Vpp into 600Ohm already. I've attached the diagram showing output voltage vs. load resistance from the datasheet in order to better explain what I mean. Cheers, Sebastian. Last edited by sek; 13th July 2011 at 07:00 PM. Reason: cleared up numbers |
| GC SuperSymmetry pt V | Nelson Pass | Pass Labs | 8 | 29th June 2004 08:26 PM |
| GC SuperSymmetry pt II | Nelson Pass | Pass Labs | 22 | 27th June 2004 08:01 AM |
| GC SuperSymmetry pt III | Nelson Pass | Pass Labs | 10 | 25th June 2004 08:42 PM |
| Page generated in 0.08821 seconds (74.59% PHP - 25.41% MySQL) with 11 queries |
