Old 20th June 2004, 07:40 AM   #1
yoke is offline yoke  Croatia
yoke's Avatar
Default x-BoSoZ volume on in or output
Hi...
Well I am building X-BoSoZ by Henrik schematic...now I'am thinking of buying series attenuator for it and have some questions...
I remember reading some where that Nelson Pass likes putting pot. on the output , after everything is said and done...but in Henrik schematic it's on Input...Should I use it on input or output ???
I mean...probably I would need to use on input any way , but for volume control , should I use attenuator on input or output ???
and If I'am gona use it on output for which value I should go ??? In BZL stage Mr. Pass wrote 5KOhm...
Old 20th June 2004, 07:46 AM   #2
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
What amp are you driving?
Old 20th June 2004, 07:53 AM   #3
yoke's Avatar
It will be Aleph-X
Old 20th June 2004, 08:19 AM   #4
wuffwaff's Avatar
you could use a balanced output attenuator if you´re driving an Aleph-X. I use one in my x-bosoz to drive my Aleph 5.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 20th June 2004, 09:00 AM   #5
yoke's Avatar
Hi wuffwaff ...
What value are you useing on output ?
Old 20th June 2004, 07:50 PM   #6
yoke's Avatar
Old 20th June 2004, 07:56 PM   #7
Banned
i use this at the output of my BZLS : http://home.tu-clausthal.de/~tpa/relais/index.html
Old 23rd June 2004, 10:28 AM   #8
wuffwaff's Avatar
I´m using 2 x 2k2 as output series resistors. You have to calculate the value for the stepped attenuator in between to get the steps you want. Using a standard log pot doesn´t work because it is way too sensitive at low values and you will always have one channel that´s still playing when the other one is already off.
William
Old 23rd June 2004, 04:32 PM   #9
diyAudio Editor
Variac's Avatar
OK, so you have output resistors in there, then short between the outputs. Yoke & I are probably using stepped attenuators, which appear to be the best for this approach, as the channel tracking is very good.
Now I guess our problem is as you say- what are good values to get a reasonable range of control with say 24 steps with this shorting approach?
Old 24th June 2004, 06:43 AM   #10
wuffwaff's Avatar
well the first step needs to be shorted (for silence) The last one open (for max. output). In between I would go for 3dB steps top down and maybe 6dB for the last 2 or 3 steps.
If you know wich output resistors you will use you can just calculate the value of the shorting resistor for any given dB value.
William
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
BOSOZ Volume Control - any suggestion ruangrit Pass Labs 15 10th February 2003 11:56 PM
BOSOZ volume control ToB Pass Labs 7 23rd August 2002 06:39 PM
BOSOZ Selector/volume control wiring? SteveA Pass Labs 4 2nd March 2002 03:07 PM
BOSOZ Volume Control rothko Pass Labs 5 23rd January 2002 03:38 AM
Page generated in 0.09750 seconds (77.16% PHP - 22.84% MySQL) with 10 queries
