New Aleph P1.7 finished last night
Old 20th June 2004, 08:31 AM   #11
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
yeah mine were only 11$ each.. ill know later on soon i think. what the difference is : O )
Lcd is getting incorporated into my pre-amp with a bunch of other goodies..
Old 20th June 2004, 08:36 AM   #12
Banned
A picture is worth more than what i can type. : O )
Here is mine..
Old 20th June 2004, 11:01 AM   #13
bbakota2000 is offline bbakota2000  Croatia
Nice job JasonL. IRF610 doesn't need heatsink at all.
I read this thread: http://www.diyaudio.com/forums/showt...954#post358954
so I decided to use Black Gates. Something better is much more expensive and they don't fit on the Kristijans boards. Too bad. Maybe one day I'll see about trying some other caps, but for now the sound is just too good to be true.
Are those BC components caps. I remember one guy from PassDIY gallery said he changed Solen MKPs to BCcomponent polypropilens and they sound much better (in Aleph P of course).
How will you implement LCD? Is it some preasembled kit or you're making one on your own?
Old 20th January 2006, 02:10 AM   #14
gaborbela is offline gaborbela  Canada
HI bbakota2000
Nice work ,it realy look nice . I purchased the same board from Kristijan but I having problem with some value . I would like to ask for some help .
First please let me know if I use N type of BG 10uF 35V if is OK or I need higher voltage . I read some were 35V would be OK but I want to be sure before I order the parts .
Second please let me know the value of R36 , I see you use resistors there . I will use 60-0 V power supply .These info for the capacitors if 35V would be OK .
I would like to ask for help ,with out help I can't go on to finnish the preamp .
Old 20th January 2006, 02:28 AM   #15
Originally posted by gaborbela
HI bbakota2000
35V is OK. Highest voltage at the output caps is around 27V, at input caps is half of that. I tried 800R resistor for R36, but the gain was too low so now I'm using Caddock 280R.
If you are intersted in 5K double ladder type stepped attenuators from my preamp let me know (bbakota2000@yahoo.com).
Old 21st January 2006, 06:04 PM   #16
finwbu is offline finwbu  Finland
finwbu's Avatar
Default enclosures
I found some enclosures for a Pass Preamp on ebay!
Here’s the link to them:
http://cgi.ebay.de/Pass-Labs-DIY-XBO...QQcmdZViewItem
Old 21st January 2006, 06:27 PM   #17
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
please note that WUFF-WAFF has nothing to do with wuffwaff
William
een ooievaar is geen konijn want zijn oren zijn te klein!
New Aleph P1.7 finished last nightHide this!Advertise here!
My finished Aleph 5 tomchaoda Pass Labs 7 4th March 2011 04:18 PM
Aleph p1.7 test run last night Jye Pass Labs 4 11th April 2005 12:41 AM
Aleph-P finished! PatPet Pass Labs 21 29th August 2004 07:43 PM
Night dreaming? / Middle of the night bloom Gabevee Tubes / Valves 54 25th July 2004 04:36 AM
Another Aleph finished! Edwin Dorre Pass Labs 31 31st October 2002 06:43 PM
