Old 16th May 2002, 09:57 PM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Maple is at the top of my list. For my CD PRO transport I plan to make a chassis out of 3/4" maple plank glued together with final size 3x10x16" of solid wood.
Old 16th May 2002, 11:05 PM   #12
jackinnj's Avatar
Default The reason that you don't use solid wood
is that it's dimensions change with changes in temperature and humidity.
Old 17th May 2002, 01:38 AM   #13
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
Not really... humidity can be an issue with cheap woods, but unless you drop it in a bucket of water, i wouldn't be that worried, trust me. The "good looking" woods have usually smal pore and are less subject to humidity also, and that's the kind of woods you want to show up. And don't forget, if you did a good job sanding and laquering/varnishing, the problem is even smaller.
For the record, i was rather concerned about the pinewood bending because of the heat (it has 4 heatsinks bolted to it running at about 50 degrees Celcius). I fired up the (final? ) version of my amp today to check some things out, and the wood didn't seem to mind at all.
Old 17th May 2002, 01:50 AM   #14
Evaas is offline Evaas  Canada
Evaas's Avatar
Exclamation nobody's scared
I've been thinking about wood for my chassis too because its easy to find and easy to work with. But I'm definitely going to stay away from soft woods like and plywood.. If something shorts out they are going to catch on fire much faster.. also watch out with the varnish you put on it. I'm confident in the quality of my work but not so confident as to put easy burning wood on top of it and cover it with flamable stuff
but thats just my opinion
Old 17th May 2002, 02:06 AM   #15
I've heard maple has nice sounding properties. Sonus Faber built their speakers from that wood. It is also quite hard.
Old 17th May 2002, 05:12 AM   #16
paulb is offline paulb  Canada
I'm thinking of an X-Aleph with maple front panel...
Old 17th May 2002, 05:49 AM   #17
Coming soon to a thread near you...
Grey
Old 17th May 2002, 08:09 AM   #18
Lisandro_P's Avatar
I'll have some pics soon of my JLH in it's wooden case (hopefully)... well worth the effort IMHO.
DIY Aleph 5 or use as Parts and Chassis kilowattski Swap Meet 2 23rd March 2009 04:13 AM
Aleph P1.7 Chassis ? dod996 Pass Labs 10 14th March 2008 03:59 AM
Does anyone want my old DIY Aleph 30 Chassis? mpmarino Swap Meet 22 19th June 2007 02:54 AM
Page generated in 0.08798 seconds (75.81% PHP - 24.19% MySQL) with 10 queries
