Aleph powersupply design question - diyAudio
Old 15th May 2002, 10:56 PM   #1
Default Aleph powersupply design question
Im not into the designings of a powersupply, but i have managed to overview existing supplys and drawn a figure of what i think should work.
Is this going to be optimal or are there places where i can optimize?
Any suggestions are welcome!
Old 15th May 2002, 11:03 PM   #2
wuffwaff's Avatar
Hello Kasra,
1. I would put the small caps after the chokes.
2. You need at least one of those 31mF caps before the chokes
Try downloading PSU-designer. I found this very usefull in designing thePI-filter supple for my Aleph 5.
william
Old 15th May 2002, 11:16 PM   #3
I am using a 20mF cap - 10mH/10A - 58mF and the ripple is quite small.
doing my part to Keep Austin Wierd.
Old 16th May 2002, 12:53 AM   #4
Whether you go with a PI, L, or T filter after the rectifier will depend on the amount of current and voltage you want. If you begin your filter stage with an inductor, you'll end up with less voltage and more current capability, even with the same transformer.
Start with the amp circuit and work backwards. Which Aleph were you interested in building? This will give you a target voltage and current draw. From there, you can begin to look at likely transformers and filter designs.
Grey
Old 16th May 2002, 10:50 AM   #5
Thank you for the replies!
Im building a pair of aleph 2 monos. The transformers i have got are 800VA 33V Toroids.
Should i do any changes to the circuit?
Wuffwaff, i tested the program didnt understand much sorry )=D
Grollins. I dont know how big the voltage drop would be if i set the inductor at the begining.
But if i have a package of different small caps before the inductor, does that lower the loss of voltages?
/kasra
Old 16th May 2002, 11:16 AM   #6
hifi is offline hifi  Sweden
I belive the purpose of the small input cap before the inductor is to keep the rectífier from beeing killed by back EMF in the coils and help reduce the current spikes that the PS otherwise would draw?
why not:
smalcap---inductor----largecap---inductor---large cap---Aleph
Btw i think this has been coverd severalt times before. In thread " PS for aleph 2" or something similar.
When using a cap you will get the peak of the sine wave i.e 1,414 and when using a coil the effectiv value i.e 0,9 ?
/micke
Old 16th May 2002, 11:38 AM   #7
Hifi, as you know i havent got room for that last inductor.
What would the difference be between the one you described and a similar without that last inductor when it comes to that sine wave multiplier number? =D
Hifi:
Perhaps i can use those 1.8mH siemens blue ones between the caps?
/kasra
Old 16th May 2002, 01:27 PM   #8
nar is offline nar
nar's Avatar
Lightbulb Aleph supply
Hi.If I were you i would try a voltage follower as the one proposed by Nelson in the part 3 of the Zen Variations.If you have enough transformer voltage to afford the 7V loss,then you should try it.I believe you would get no audible hum due to power ripple.
If you have not enough space for the inductors try it.Or if the voltage of the transformer is a bit low to afford it,then do only the version without the zener diodes.You would get a 4V loss and the supply will not be regulated,but should take away most of the ripple.
Try it and tell me if it works narshornsyst@hotmail.com
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 16th May 2002, 05:31 PM   #9
Actually i dont afford any voltage loss. Neither have i got any space =/
Would the circuit i drawed give any voltage loss?
/kasra
Old 16th May 2002, 09:45 PM   #10
Kasra,
I´m not an expert in this subject,
but I would put the inductors between the large Rifa caps and I would paralell all the large caps with, for instance, a 10-100 uF SCR/Solen.
This configuration would give you max. voltage (and good sound I guess).
Accordingly to my high voltage tube experience the RIFA PEH 169 is not a very good sounding cap. Perhaps it is better for low voltage operation or you may have a different opinion that I have.
Good luck!
powersupply design question casiomax Chip Amps 88 1st September 2008 09:15 AM
Aleph powersupply Skorpio Pass Labs 7 7th December 2005 12:16 PM
Aleph-X powersupply Dr.Gone Power Supplies 11 18th July 2005 07:47 PM
Aleph X powersupply PatPet Pass Labs 10 3rd June 2004 03:44 AM
Aleph 2 LC powersupply ...question.. hifi Pass Labs 16 3rd February 2002 05:27 PM
Copyright ©1999-2017 diyAudio
