Old 7th June 2004, 01:10 AM   #1
Default TIP29 in my Bride of Zen
Hello, I just want to talk about something in my Bride of Zen amplifier power supply.
At the output of my 30-30v transformer, I have 95Vdc, so, at the output of the regulator, I have 60v. My TIP29 have to burn 35V!
After a couple of minutes, My TIP29 is very very hot, It is imposible to touch it, it is to hot. I have a little heat sink on it, like the one on my mosfet....
I see two solution:
1- Use a bigger heat sink.
I don't want to do that because it will be physically difficult
2-Put a power resistor between the 95v and the Collector of the transistor.
To that, I need to have the current draw of the preamp, I'm not sure about this, maybe 100mA ?
If that, the resistor will be 35/0.1=350 ohm ???
Thank you !
Old 7th June 2004, 02:24 AM   #2
Account Disabled
Another solution could be reducing the bias from about 40mA to about 30mA, by adjusting R108—i.e. V across R108/R108 = 30mA. I have tried with 30mA with a still good sound.
Old 7th June 2004, 07:05 AM   #3
Account Disabled
Further to post#2...
The reduction of the bias could be possible simply by adjusting P102 till the voltage across R108 reaches about 3V. If so, this method does not require any addition, deletion or change of component.
Good luck.
Old 7th June 2004, 02:48 PM   #4
Henrik is offline Henrik  Denmark
arnold19
Take a look at this post and the discussion around.
http://www.diyaudio.com/forums/showt...804#post285804
Henrik
Old 7th June 2004, 02:55 PM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: TIP29 in my Bride of Zen
I see two solution:
Thank you !
If you have 95VDC from your 30-30V transformer, I suggest that is the real problem. (I assume you rectify the two 30V secs in series with a bridge). Maybe you should get another transformer, for the pre-amp this would not be too expensive?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 8th June 2004, 06:11 PM   #6
Anorgan is offline Anorgan  Croatia
Anorgan's Avatar
This are my heatsinks. Tip doesn't get hot - it's warm. That 5W resistor gets hot
So see for yourself if you have a smaller heatsink or something is wrong with yours (i remember you had some trouble with it).
Old 18th June 2004, 10:11 PM   #7
Default picture
Here the picture of my preamp. He can see the little heat sink on my tip29 in the bottom at the right of the pic...
Old 18th June 2004, 10:14 PM   #8
Default more picture
Here more picture of my preamp!
Old 18th June 2004, 10:16 PM   #9
one more
Old 18th June 2004, 10:17 PM   #10
the last
complementary pairs tip29 tip30 Acoustat Solid State 3 4th April 2009 08:33 PM
BOZ builders - Here's a source for TIP29 KT Pass Labs 4 30th November 2005 05:15 PM
BOZ: Replacement for tip29? KT Pass Labs 22 25th December 2004 10:51 PM
Bride of Zen, Bride of Son of Zen 2Bak Pass Labs 4 12th May 2002 04:51 PM
Bride of Son of Zen vs. A;eph P Peter Daniel Pass Labs 0 25th January 2002 07:45 PM
Page generated in 0.10831 seconds (81.51% PHP - 18.49% MySQL) with 11 queries
