Old 4th June 2004, 07:15 AM   #1
elviukai's Avatar
Thumbs up new irfp mosfets
hello guys, what is the best choise for aleph 3/30?
here is no 244. but are theese:
IRFP064N (MOS-N-FET 55 V 110 A 200 W 0,008 Om TO-247)
IRFP140 (MOS-N-FET 100 V 27 A 140 W 0,052 Om TO-247)
IRFP150 (MOS-N-FET 100 V 40 A 230 W 0,06 Om TO-247)
IRFP260 (MOS-N-FET 200 V 46 A 280 W 0,055 Om TO-247)
or 240???
I am thinkingo of 064 model at a price?
any help is welcome..
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!..
Old 4th June 2004, 12:43 PM   #2
elviukai's Avatar
anybody?
Old 4th June 2004, 12:55 PM   #3
Andypairo's Avatar
The 064 might not suit due to the total rail voltage of the Aleph30, all the others can be used.
My Aleph30 uses IRFP150, my Aleph-X the 140.
The IRFP240 is quite popular but I'd say go for the cheapest
Cheers
Andrea
Old 4th June 2004, 12:56 PM   #4
Default irf244 replacement
Most popular replacement is IRFP240.
I have used and prefer IRFP150.
Old 4th June 2004, 02:28 PM   #5
The IRFP240 is a good general purpose choice
and I seem to remember it being also one of
the cheaper ones. You can buy a bunch and be
building different Alephs and Zens for quite a
while.
That said, my A30 uses IRFP044's since I
happen to have them on hand and they
worked fine. I wouldn't use them with
higher voltage rails though.
Dennis
Old 4th June 2004, 05:13 PM   #6
Default Re: irf244 replacement
Could you please tell us why you prefer the 150?
Jan
Old 4th June 2004, 07:49 PM   #7
The one and only
Nelson Pass's Avatar
Odd, I posted a reply and later couldn't find it.
In any case, I have pointed out before that the IRF250 is
a bit like two IRF240's in parallel, and the same is true of the
150 / 140. It has more transconductance and capacitance
and dissipation capability.
If you want to use it instead of a 140 / 240, then consider
using fewer in parallel, otherwise there is a bit of spectral
shift toward the bottom end. If you want better bass, that's
a fine way to get it.
Old 4th June 2004, 10:21 PM   #8
Jan,
Mr. Pass summed it up perfectly. And before I started building
the Aleph I "auditioned" a few different FETS in a pair of ZEN's.
To me IRFP150 was the winner, closely followed by IRFZ044N.
The later is in TO220 package.
I have also used them (the 150's) in two Aleph-X's.
Old 5th June 2004, 08:01 AM   #9
A 150 has more dissipation capability. This means that it get's less hot if used instead of a IRF240? Or described in another way: if you use 6 IRF150's in an Aleph 5, you need less heatsinking?
Jan
Old 7th June 2004, 07:04 PM   #10
The one and only
No you need the same amount of heat sink for the same
temperature.
Irfp 240 !!!!!!!!!! jeclk Pass Labs 5 11th November 2003 05:00 PM
Values of my IRFP 240 Mosfets Hydesg Pass Labs 12 7th October 2003 02:47 PM
Fairchild IRFP NHul Pass Labs 0 16th February 2002 09:12 AM
IRFP transistors AuroraB Pass Labs 5 14th February 2002 05:44 PM
irf 240 or irfp 240 for the aleph scu Pass Labs 2 14th January 2002 06:49 PM
Page generated in 0.11327 seconds (79.14% PHP - 20.86% MySQL) with 10 queries
