Bride of Zen, Bride of Son of Zen
Old 9th February 2018, 09:28 PM   #81
mjf is offline mjf  Austria
attenuation at the output:
e. g. paralell a 10k res to your 10k pot - this gives you a "5k pot load" similar to the original schematic and decreases the output signal.
Old 9th February 2018, 09:58 PM   #82
darrr is offline darrr
Good idea I must try. On your diagram is R3 100k which isn't in the original BoZ.
Old 10th February 2018, 07:32 AM   #83
r3 100k is only for sim purposes (e. g. input impedance of an amp.......)
annother option......if you build in a 820 ohm res instead the 1k drain res (or
paralell a 4,7k res to the 1k ) the gain will decrease.......(around 4 x)
Old 10th February 2018, 07:50 AM   #84
.....and at last.......lower r12 (10k) to 4,7k or so..... attenuates the signal a bit.......this is a little bit crude, but it helps.
(or you try out to change r3 at the output with 4.7k .......)
Old 10th February 2018, 09:56 AM   #85
I suppose that your r3 is useless in my BoZ I'll change and listen until I get to the best sound. Thank you for your help
Old 10th February 2018, 08:27 PM   #86
Something wrong with one channel. After few hours of listening music I measured bias and now it's looking like this. I cant increaese bias becouse now pot is in max position
Old 11th February 2018, 09:41 AM   #87
i guess the boz was hot......
are the voltages in the normal region when the boz is cooled down?
(all transistors in the boz need a proper heatsink!)
Old 11th February 2018, 10:10 AM   #88
voltages are the same when it starts and after few minutes.(3.0 on beginning , 3,4 after few minutes) Heatsinks of course are installed. Irf on this channel is colder than the other.The same r104(1K)
Old 11th February 2018, 01:39 PM   #89
I withdrew a few turns on P102 and now the measurements look like this.
Old 11th February 2018, 02:58 PM   #90
.......yes, the current is low.....less heat.
the boz has only a few parts to measure, so check every res (ohm) with your dmm......
is the 100uF (c102) electrolytic cap built in the right way?
if they all are correct, search for a bad soldering point/lost connection.
......and the 1uF input cap not to forget......
Bride of Zen, Bride of Son of ZenHide this!Advertise here!
New PCB for bride of zen maartentje Pass Labs 6 28th February 2005 07:19 AM
Bride of zen PCB maartentje Pass Labs 8 14th February 2005 01:26 AM
bjt bride of zen renjiish Pass Labs 1 24th September 2004 03:54 PM
Bride of son of zen -----> WHERE? m60gpmg Pass Labs 6 23rd September 2002 09:08 PM
Bride of Son of Zen vs. A;eph P Peter Daniel Pass Labs 0 25th January 2002 07:45 PM
