Bride of Zen, Bride of Son of Zen
Old 11th February 2018, 03:17 PM   #91
darrr is offline darrr  Poland
I'll check. Now I have p102 on max and bias is 2,8v if plugged in rca with CD but wihout rca it's 5,0v. Second channel still 5,6v. Caps are in good direction.
I found- R105 is ca. 70k but I'm 100 % sure that it was correct 100k
Old 11th February 2018, 04:28 PM   #92
mjf is offline mjf  Austria
........input cap 1uF could be damaged......
Old 11th February 2018, 04:53 PM   #93
not 100k? should I change channel to check it?
Old 11th February 2018, 05:04 PM   #94
you can solder out the 1uF cap and measure again.......
Old 11th February 2018, 05:29 PM   #95
wow. There is 2,9v on input before 1u.there are 1u/400v jantzen audio. what kind can I replace? maybe some bigger for example 3u3?
Old 11th February 2018, 05:44 PM   #96
.......you mean 2,9V on the node 6,2k and 100K (without cd-player connected)?
1uF is big enough i think , this gives you low pass frequency lower than 2Hz....
Old 11th February 2018, 06:04 PM   #97
Yes, I unplugedd CD an 2,9v was on rca in. I soldered it out - there is 10Mohm on cap. Now all points measured looks ok ,
Old 11th February 2018, 06:36 PM   #98
I am concerned about that problem with cap-what was the cause of damage becouse everthing was ok
Old 13th February 2018, 10:00 AM   #99
I have replaced the damaged jantzen cap with a cheap replacement and now all voltage values ​​are stable.
Old 13th February 2018, 02:53 PM   #100
a damaged cap at the input is a rare event.........
Bride of Zen, Bride of Son of ZenHide this!Advertise here!
New PCB for bride of zen maartentje Pass Labs 6 28th February 2005 07:19 AM
Bride of zen PCB maartentje Pass Labs 8 14th February 2005 01:26 AM
bjt bride of zen renjiish Pass Labs 1 24th September 2004 03:54 PM
Bride of son of zen -----> WHERE? m60gpmg Pass Labs 6 23rd September 2002 09:08 PM
Bride of Son of Zen vs. A;eph P Peter Daniel Pass Labs 0 25th January 2002 07:45 PM
