Old 1st June 2004, 04:07 AM   #1
Default I want pre-amp schematic with A s/n ratio 92 db or more
I want pre-amp schematic, please.
with a s/n ratio 92 db or more.
I'm new in pre-amp. never have one.
tiger.
jinkuchi
Old 1st June 2004, 04:01 PM   #2
The one and only
Nelson Pass's Avatar
A weighted? No weighting?
Noise Floor? Wide band?
What voltage did you want that 92 dB referenced to?
Old 2nd June 2004, 03:25 AM   #3
the signal to noie ratio
I mean approximately.
Just want high quality preamp that has low noise.
thank you
jinkuchi
Old 2nd June 2004, 08:37 AM   #4
If you want your preamp to be able to accept 2Vrms at it's input, then if the input noise must be lower than 92dB, this will equal:
2 x 10^-4.6 / sqrt(20KHz (bandwidth)) = 349nV/sqrt(Hz)
It's hard to design something so noisy. Every opamp known to me has an input noise lower than 40nV/sqrt(Hz), take you pick, NE5534, or opa227 (both about 3.5 nV/sqrt(Hz)), opa134 (about 8nV/sqrt(Hz) ? ).
Edit..: oops allmost forgot: Nelsons MOSFET preamps will meet this criterium too. BTW what is the EIN of a IRF610? something like 20nV/sqrt(Hz) ?
But if you want 92dB S/N for a 2mVrms (max input) preamp, you'll have a challange... you'll have to build a discrete BJT preamp, eg. a 6 transistor symmetrical input stage with Vbc = 0Volt and 300uA Iq each transistor, or a handfull 2SK170's in parrallel...
Goodluck,
Thijs
Old 2nd June 2004, 09:37 PM   #5
The one and only
That's what I get, too.
You will be amused to know that the output noise of the First
Watt amp is about 20 uV, for an output floor of about 140 nV,
and an input floor of about 28 nV using an IRFP240 pair.
MuuuHahahahaha
Old 3rd June 2004, 02:22 AM   #6
wrenchone's Avatar
Nelson, do you twirl your moustache when you do that scary laugh?
Old 3rd June 2004, 03:30 AM   #7
grataku is offline grataku  United States
What does it matter what the thermal noise of the preamp is if what you are getting from the trafo and poor grounding and ripple is going to be 40 db above that?
Old 3rd June 2004, 11:11 AM   #8
how about transistor 2sc458?
jinkuchi
Old 3rd June 2004, 12:17 PM   #9
I found this datasheet, but I cann't find any info on the noise specs. But generally, a discrete BJT preamp design can be made to have excellent noise performance, especially with low Z sources, pretty much with all comman transistor types.
http://s89326750.onlinehome.us/maran...ecs/2sc458.pdf
Old 3rd June 2004, 12:23 PM   #10
Electrons are yellow and more is better!
peranders's Avatar
Default Re: I want pre-amp schematic with A s/n ratio 92 db or more
tiger.
Are you after a preamp of "Nelson" style or any style?
Do you mean 92 dB at fulll, output?
A plain transistor has 1-3 uV noise max => 100-120 dB
/Per-Anders (my first name) or P-A as my friends call me
Sub to Amp power ratio DanSR20DET Car Audio 11 3rd January 2009 02:50 PM
Oversampling ratio beauty_divine Digital Source 1 10th September 2006 10:52 AM
So/Sl ratio? Tomac Multi-Way 3 14th January 2004 11:48 PM
Page generated in 0.09741 seconds (77.88% PHP - 22.12% MySQL) with 10 queries
