Aleph 60 mystical resistors
Old 9th May 2002, 11:01 PM   #1
Gabster is offline Gabster  Canada
Gabster's Avatar
Default Aleph 60 mystical resistors
Here're my last questions before I can buy all the stuff for my Aleph 60 and start the building process
1) What are the values of R1 and R8. There's only an * on the schematics?
2) R19 = 5622 = 5.622k = 5.62k ?
3) R21 = 1501 = 1.501k = 1.5k ?
4) On the Aleph 2, there was a thermistor in the power supply (plus the one to the ground). Why is this thermistor missing? Will the amp power up smoothly ?
5) Same question regarding the missing capacitor between C20 and Q4 (Aleph 60)?
6) Is it OK to use 5% 3W resistors?
thanks,
Gabriel
Old 9th May 2002, 11:31 PM   #2
Karen is offline Karen
Karen's Avatar
For Aleph 60, R8 can be used to adjust any DC offset, if it occurs. R19 is 5.62K and R21 is 1.5K. Hope that helps.. Also, careful with the value of R19, this resistor sets the bias..
..K
Old 10th May 2002, 12:13 AM   #3
GRollins is offline GRollins  United States
Warning: I'm short on sleep and cross-eyed as a result...
but I think R19 is more likely to be 56.2k
I used the Panasonic 3W resistors from Digikey; they're 5% and work just fine.
The thermistor is to slow inrush when you first turn the amp on. Feel free to put one in if you like. Either way, be sure to use a fairly hefty switch. If all else fails, buy a double pole switch and wire the two sides in parallel. The next step after that is to put a 600V .1uF (some people say .01uF) cap across the switch to suppress the spark as the switch makes or breaks contact. If you really want to guild the lily, build a slow start circuit or use a Variac to bring the thing up.
The cap can be added if you like. It's there for stability. I changed my mind about ten or twenty times as I was building my amps, eventually deciding not to put it in...but I hedged my bets by making a place for it on the circuit board, and bought the caps anyway just in case I decided to put them in late some Saturday night. Mine are stable, but then I run them into a very tame load--both pairs are pushing purely resistive drivers. If I were using electrostats or something really freaky, I would consider using the cap.
Grey
Old 10th May 2002, 12:32 AM   #4
BRunenr is offline BRunenr
In some schematics Mr. Pass uses this convention: resistor values are given as "three digit and multiplier", which means that 1000 in the schematic is a 100 ohm resistor, 1001=1k, 1002=10k and so on..
Old 10th May 2002, 12:39 AM   #5
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
R19 = 56.2K
R21 = 1.5K
Old 10th May 2002, 07:14 PM   #6
Karen's Avatar
Oops, Excuse me, 56.2K.
..K
Old 10th May 2002, 07:32 PM   #7
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
You can dress her up, but you can't take her out
Old 10th May 2002, 07:34 PM   #8
Karen's Avatar
I knew that one was coming. DUCK!
..K
Old 10th May 2002, 07:35 PM   #9
HarryHaller is offline HarryHaller  United States
Banned
Unhappy Karen
You leave that fine lady alone. She may be the only touch of class on this whole sorrid forum!
H.H.
Old 10th May 2002, 07:38 PM   #10
S'alright, dahlin', I'll take you out.
Given some of the disjointed nonsense I've been spouting recently, it's a wonder they haven't pulled the plug on me. Once I get a little sleep, maybe I'll be more coherent, myself.
Grey
Aleph 60 mystical resistorsHide this!Advertise here!
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
Esotar 330: Measured Science or Mystical Fiction? leifislive Multi-Way 24 26th June 2008 07:17 PM
Artist with the most mystical albums rick57 Music 32 10th April 2006 07:39 AM
Resistors in Aleph-X Hastur Pass Labs 8 7th February 2006 10:18 AM
Resistors in Aleph 2 diyman Pass Labs 1 4th May 2003 06:57 PM
