Hello, for the power network on Class A amp, compare with "CRC" & CLC , which one is the better choose? is the result is different ?
Many people said that CLC is for high current (class A amp) , is that ture ? |
#2 |
The L in a CLC needs a minuimum current to regulate, and stops
regulating if the current is too high and it saturates, so its ideal for the supply of a constant current class A output stage. CRC does not have minimum or max currents so is better for class aB but of course the voltage drop across the R is not good at high currents, so not popular for output stages. CRC is popular when you can significantly reduce voltage without effect - e.g. decoupling the input stage of an amplifier. |
| Compare of opamp’s | bdef | Analog Line Level | 6 | 9th November 2006 06:22 PM |
| Where should be fb compare to fs | ostie01 | Subwoofers | 8 | 9th May 2006 10:56 AM |
| How do they compare???? | DJNUBZ | Solid State | 1 | 26th April 2005 12:12 AM |
| compare the Boz & Bls | billy | Pass Labs | 1 | 9th February 2003 02:09 AM |
| Mic compare to wealthy Ear | A'af | Multi-Way | 9 | 11th January 2003 01:25 AM |
| Page generated in 0.05225 seconds (78.86% PHP - 21.14% MySQL) with 10 queries |
