Danish - GamuT Audio, former Sirius have been producing "High-end" amplifiers for more then 2 decades. And they have always been faithful to their special topology - single Mosfet output stage.
They are using industrial Mosfets. Could I use these Mosfet in a Pass amplifier with excellent result, and instead of more IRF Mosfets in parallel? ![]() From their web site: http://www.gamutaudio.com/ This new technology offers two major advantages: A smooth and detailed sound quality, which until now only was available in a few low powered class A power amplifiers. Improved reliability, 4 parallel transistors gives 4 times higher chance of a breakdown, compared to 1 transistor. |
#2 |
The one and only
The Gamut apparently uses a single pair of complementary
output devices. I don't happen to see the merit of their philosophy, especially since quite a few of the "industrial" devices consist simply of paralleled devices in a single package. |
#3 |
the advantage comes in on the bottom line...
Jesus loves you. |
#4 |
Industrial 'bloc' transistors are made for switching, not linear use.
IR told me that they won't even be sure the individual die are from the same date lot, much less matching Vgs. Semelab being lateral devices is not as bad, however, there are no individual gate stopper resistors and they may oscillate. |
#5 |
The one and only
I bought a few of these, and as far as I can tell there
is OK internal matching, but only because the machines that take the die from the wafer do so in a systematic pattern, not through any effort on IR's part. This is the same phenomenon that you see taking parts out of tubes, where you can sequentially trace the location of the parts on a circular wafer based on the matching and you get a sequence that vaguely resembles the periodic table of the elements. |
#6 |
75V 470W IRFP2907-ND $3.96
100V 580W IRFPS3810-ND $4.04 500V 460W IRFP32N50K-ND $5.04 The industrial 'block' packages go for $35~$50 each These are TO247 and 'super' TO247 packages. The 100V one might work well in a circlotron. |
| AB outputstage | klingest | Solid State | 2 | 5th May 2009 07:37 AM |
| MF x10v3, xcans v3, trivista, a5 outputstage | lt cdr data | Digital Source | 12 | 30th April 2007 02:40 PM |
| What outputstage should you use with PCM1704 | Ryssen | Digital Source | 0 | 6th January 2004 05:20 PM |
| Tube outputstage | Ryssen | Digital Source | 8 | 17th December 2003 03:58 PM |
| Page generated in 0.08237 seconds (72.81% PHP - 27.19% MySQL) with 10 queries |
