Plz Help i think iv'e just distroyed my amp
Old 20th May 2004, 09:37 PM   #1
Rixsta is offline Rixsta  United Kingdom
Angry Plz Help i think iv'e just distroyed my amp
My zen 4 has been running fine until i just turned it on and i get a very load buzzzzzz.
it sounds like 50hz and it slowly fades away when i turn the amp off...
well it was working ok or perfect even, the transformer was a bit warm but thats all. and im running it bias at 1.5 amp
It's a zen 4 penultimate and it effects both channels dam it id only just today got it working and was enjoying the qualty and realising how bad mp3 actualy sounds too..
I do have one theory and that is i might of had a bad rca/phono connector on the input maybe the earth is faulty on it and cause the input transistor to blow..
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 20th May 2004, 09:43 PM   #2
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Rixsta,
do you use a shared power supply for the two channels? If so it sounds like a cap has gone.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 20th May 2004, 09:45 PM   #3
theres two seperate windings on my toroidal transformer i have 1 rectifier on each and one cap on each rectifier
i think thats basicly a shared transformer
if i charge up a new good cap and put it onto the amp alone i will find out right?
Old 20th May 2004, 09:48 PM   #4
wuffwaff's Avatar
but do you use this supply for both channels?
If so check the caps and the wiring to the caps, if you´ve got an scope you should see a large ripple on one of the two caps (or on both)
William
Old 20th May 2004, 09:54 PM   #5
Yes
i have no scope but i will replace the cap's or one of them one channel at a time.
the cap's are different so i dont see why they would both go at the same time unlss the transformer killed them or too much power was drawn from the PS
Old 20th May 2004, 10:04 PM   #6
Ok i know im only a ammiture at electronics but i just hocked up a 20v power supply to it and when i touch the ground of the speaker outs it buzzez. as if they were the inputs to the amp
Old 21st May 2004, 11:30 AM   #7
Panelhead is offline Panelhead
Sounds like a grounding issue. Check all your solder joints and pull on wires to verify good connections.
If you used the Passdiy boards, check solder connections. It takes a 40 watt iron to make good connections on some of the ground plane pads.
George
Old 22nd May 2004, 01:49 PM   #8
thanks
Iv'e just fond out my amp is ok it's my graphic eq thats gone wrong makinmg a badd hummm
cheers
Plz Help i think iv'e just distroyed my ampHide this!Advertise here!
I distroyed my preamp: dc on imput wazzup Analogue Source 5 29th November 2004 08:47 PM
Penultimate zen all mosfets distroyed Rixsta Pass Labs 65 21st April 2004 01:57 PM
Copyright ©1999-2017 diyAudio
