I would like to say thanks to nelson pAsS for the great design of all his amps and having heard the penultimate zen which is what i am building, i notice why "class a" is so often talked about...
anyway my problem is one channel of my amp dosent even power up there is no voltage on the source or the gate of Q5. I also test for voltages at the zener diodes and get no reading .. so i guess either one of the five zeeners have been distroyed or D1 or maybee even Q5 itself. of course theres the possibility that i am overly tired and can no longer concentrate properly, in that case forgive me for asking such a dumb question. thanks for the help in advance.. (presuming someone will help...lol...duh)
#2 |
George |
#3 |
cheers George
my connections all seem to be fine it's S t r a n g e indeed |
#4 |
ok iff all my connections are fine whats going on ?
This cant be normall can it ? |
#5 |
hi rixsta,
You may try to check the voltages from the source backwards. Check volatage across capacitor C10. Check drop across diodes and zeners. There has to be some drop across the diodes. If as you say, you measure nothing - then try isolating Q5 before you measure the voltage. In this way you can nail down the faulty component. Hope this helps regds |
#6 |
Try tracing the supply voltage from the PSU and inwards, you should be able to see that it dissapears somewhere. Once you can tell where that is, Im sure somebody here whom have built the ZV4 can sort you out....without that information its down to wild guessing.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#7 |
Is it possible D1 was in backwards and smoked R18?
Take D1 and Z1 out and see if there is a voltage. Check the values of R17 and R18. Are C9 and C11 in correctly? Good luck, Mike
MikeW |
#8 |
cheers all
im about to check out what you said. where it says 46V on the schematic i have none or maybe half a volt or less. so once 50v crosses D1 theres no voltage. and q5 (or something) |
#9 |
ok iv'e sused it
i just disconnected the five zeners and all is well obviously i had them make up the wrong voltage |
#10 |
| PC Power Supply Mod - Quick question for someone with an EE etc. | calee4nyaboy | Parts | 7 | 31st December 2009 05:10 PM |
| Quick subwoofer/amp power question | anglerz007 | Car Audio | 6 | 16th September 2006 03:29 AM |
| A quick question about battery power | Thunau | Power Supplies | 5 | 23rd March 2006 08:16 AM |
| Quick TT power supply | scott wurcer | Analogue Source | 2 | 11th February 2004 10:49 AM |
| quick Q on power supply caps | theChris | Parts | 3 | 5th November 2003 05:50 AM |
| Page generated in 0.09367 seconds (80.65% PHP - 19.35% MySQL) with 10 queries |
