Threshold Stasis 3, too
Old 18th May 2004, 09:13 PM   #1
Roscor61 is offline Roscor61  Italy
Default Threshold Stasis 3, too
Hallo,
thank Nelson for the information on power bipolar transistor.
An other little question:
subject: Threshold statis 3
How may mA on positive rail of bias current with input grounded?
Is this the method to measure it?
thank you for the attention
Rosario
Old 19th May 2004, 08:57 PM   #2
docjoe is online now docjoe  Europe
docjoe's Avatar
Default stasis 2
hi
we've just finished the rejuvenation of a Stasis 2 amp,after much trouble with oscillations; however everything fits in place now.
we have biased the amp at approx. 0.650 mA total idle current, which gives a temperature of the fins at about 40 C. near the PCB, that is at the back of the amp; as Nelson once wrote me , it is hot but not painfull to touch!!
we measure bias at the fuse holder on B- rail,
hope this helps
more if you need
ciao
docjoe.
Old 19th May 2004, 11:01 PM   #3
Petter is offline Petter
Just set up the unit to run at the desired temperature.
While you are at it, please consider replacing the cheap shitty single turn potentiometer with a nice 10 turn one. It will make it infinitely easier til set it up.
Beware that the unit will drift so when you have it set, you need to check the temperature frequently as you build it up from zero.
Petter
Old 20th May 2004, 09:12 AM   #4
docjoe's Avatar
Roscor61
As a post scriptum, see these threads about stasis amps :
http://www.diyaudio.com/forums/showt...=&pagenumber=2
or :
http://www.diyaudio.com/forums/showt...153&highlight=
docjoe.
Threshold Stasis 3, tooHide this!Advertise here!
threshold stasis 2 docjoe Solid State 3 10th November 2012 12:05 PM
Threshold Stasis 2. steenoe Pass Labs 52 29th August 2007 06:59 AM
Another Threshold Stasis 2 rebuild AMV8 Pass Labs 2 22nd December 2006 05:13 AM
Threshold Stasis S/300-2 optical a-ab georgehifi Solid State 3 30th September 2003 02:18 PM
Copyright ©1999-2017 diyAudio
