N.E.W A-60 Class A heatsink N.E.W A-60 Class A heatsink - diyAudio
Old 17th May 2004, 10:28 PM   #1
vsr123 is offline vsr123
Question N.E.W A-60 Class A heatsink
Hi Folks
I know this has been a sore subject in the past but I could not find the following information for this amp -
Does anyone know how many watts of heat this chassis is capable of dissipating? I could not find any measurements/size of the heatsink. Based on the wattage (60W/channel) I am assuming that it could do at least 100 W of heat with a 30C rise, hence effectively giving a .3C/W heatsink capability but I also heard that this amp ran very hot...does anyone know?
thanks
vsr
Old 17th May 2004, 11:37 PM   #2
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Your estimates are very good.
I gutted an A60 (Nelson would be proud!) for my Penultimate Zen. I'm running the channels at 100W each and they run around 55 degrees C.
I bought several chassis when they went tits-up. Paid a tidy sum, but they're perfect for many of the Pass projects and I like the element of revenge / irony.
Old 18th May 2004, 12:41 AM   #3
Default many thanks
great! that means I should be able to run an Aleph 3 without any problems!
Old 18th May 2004, 09:04 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The NEW heat sink will be very hot at 100 watts dissipation.
I have used its equivalent for 20 watt Zens, drawing about
50 watts per channel, and that was an acceptable temperature.
Old 18th May 2004, 10:22 PM   #5
AudioMaker.Tech
With due respect, to the Zen master...
Is it possible you are thinking of the smaller N.E.W heatsinks? I'm using the A60 sinks dissapating around 95-100 watts at 55 degrees C.
Oh, I forgot to mention the ambient in my listening room is 10 degrees C. Just kidding....
Thanks, sir.
Old 19th May 2004, 02:38 AM   #6
AudioMaker.Tech
VSR123:
Hears my ZV4 in the A60 chassis. Oriented horizontally to show the insides - digital thermometer attached to heatsink. The "Kil-A-Watt" meter (behind) reads 230 Watts power drawn from the wall.
Old 19th May 2004, 02:41 AM   #7
AudioMaker.Tech
Here's another view:
Old 19th May 2004, 06:24 PM   #8
Default thanks much
I have decided to go with a bigger heatsink chassis as I want to be able to upgrade it to an Aleph 5 or Aleph-x monoblock in time
thanks for all your help
Old 19th May 2004, 06:25 PM   #9
Thumbs up Very neatly done, nice wiring work
Old 19th May 2004, 07:31 PM   #10
The one and only
My daughter runs one just like it, but with a selector switch
and volume control.
N.E.W A-60 Class A heatsinkHide this!Advertise here!
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 10:25 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
ab class heatsink dimensioning morpheus82 Solid State 6 21st April 2005 09:35 PM
Copyright ©1999-2017 diyAudio
