Dear Fathers of Bride Of Zen,
I plan to upgrade the power unit of my Bride Of Zen preamp. I want to upgrade my current transformer (toroidal, 60 VA, 2x30V). Do you think that 160 VA will be a significant change ? What about the 1000 uF caps (C1,C3,C4,C101) ? --> 4 x 4700 uF ? And the diodes (now 1N4004) ? |
#2 |
Hi Gubby
1 - I´m using Avel 160 VA , 2x30 in my BOZ, no problem. 2 - 2200uf for PS is a good option. Larger caps are not necessary for a preamp, IMHO. Yet you may need to increase mains fuse capacity due to higher starting current. 3 - 1A fast-soft recovery diodes are far enough too. The best upgrade for the money are the 1,0 and 10,0 input caps. A lot of BOZ ownners put 0,01 mf high quality film and foil bypass caps on them. Regards, JC |
#3 |
If you are adventurous, try an extra large tranny. When I first built my BOZ, I only had a 30+30 @ 5amp tran. The sound had great transient response and bass. I later used a 1 amp trans and it didn't have the punch the 5A did.
I read about this in Stereophile some years ago where John Curl used consecutively larger transformers in a preamp design and with every increase in size, the sound became more detailed. Vin |
#4 |
Many thanks for your help.
I think I'll try a 300 VA or maybe 2x160 VA. Stay tuned... |
| upgrade transformer? | ipop07 | Tubes / Valves | 6 | 22nd August 2008 06:53 PM |
| Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? | jpchleapas | Digital Source | 1 | 31st January 2008 07:18 PM |
| MTX amp unregulated, transformer upgrade? | gxenakis | Car Audio | 7 | 29th April 2007 03:34 PM |
| wich design?? | wuffer | Multi-Way | 0 | 1st January 2005 09:55 AM |
| Page generated in 0.07857 seconds (68.31% PHP - 31.69% MySQL) with 10 queries |
