Old 12th May 2004, 11:05 AM   #1
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
Question Zen v5 power supply heatsink
Hi guys!
I almost finished my zen V5 and I'm dealing with heat problems with Q3 and Q4 of the power supply. With a small heatsink It get over 60ºC in 10 min or so.
How does one know what is dissipated power of the fets?
I have 24V regulated and the amp is biased at 1.5A.
Pedro Oliveira
Old 12th May 2004, 12:28 PM   #2
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Pedro! good to see you. glad to see you're still around.
I'm not sure how you can figure the dissipation of those FETS,
but it seems like you may need a bigger heatsink for them, or if
you can't do that, put a small fan on it.
...or let it sit for an hour and see what your max temp is. If it's
around 60C maybe just let it be?
m.
Old 12th May 2004, 01:11 PM   #3
PedroPO's Avatar
Yes I'm still here, just a little to bussy to do the good stuff
My sinks are very small (3x5 cm) and if the temperature arrives at 60ºC in just 10 minutes I wonder what will happen in a hour or so
if I use a clamp meter I could measure the current flowing trough the fet, but I'll need to take it from the board were it is right now.
I'll send a pic later with the amp as is.
Pedro Oliveira
Old 13th May 2004, 09:59 AM   #4
PedroPO's Avatar
here is the promised picture.
See the size of the sinks in the psu.
they are small, but how bigger do they need to be?
Pedro Oliveira
Old 13th May 2004, 10:24 AM   #5
joensd is offline joensd  Germany
Power dissipation depends on your "input voltage" of the regulator measured after the coils (so at C5).
(Measured voltage minus regulated voltage) multiplied with bias.
I think the regulator is well described in the ZenV3 article.
Old 13th May 2004, 10:27 AM   #6
moe29's Avatar
Pedro, I wouldn't be surprised if those fets weren't dissipating
around 20 watts each - maybe more.
When i was using a regulated power supply on my SOZ i mounted
the FETS on the main heat sinks. Zen version 4 does the same thing.
Old 13th May 2004, 10:36 AM   #7
Even if you leave out the "zener string" the fets dissipate around 4V*bias and so 6W.
It´s hard to judge the height of your sinks but they look fairly small even for 6W.
Put them on the main sink like moe29 suggested.
Old 13th May 2004, 12:00 PM   #8
PedroPO's Avatar
can't do it. the psu will be on a different case.
I'll use big heatsinks in the psu
Pedro Oliveira
Old 13th May 2004, 09:12 PM   #9
Keep in mind that exterior heatsinks where the air can flow through the fins from the bottom (in comparison with your PCB-mounted heatsinks) will be much more effective.
Depending on dissipation they probably don´t have to be SO big.
To get it cheaper you could also regulate a bit higher, say V+ is 28V. So you "move" some power dissipation from the PS-regulator to the amp. Regulation should be sufficient if you still have at least 4V margin to the voltage after the inductors.
Old 13th May 2004, 09:38 PM   #10
azira is offline azira  United States
Default Re: Zen v5 power supply heatsink
Originally posted by PedroPO
Hi guys!
Measure the voltage from drain to source of your FETS. Multiply by current through your fets.
Power = V x I
Danny
Mica in Heatsink TO3 power transistor or no ? aldovan Solid State 2 6th June 2008 03:39 AM
Heatsink for two STK4050V in maximum power ElectroPower Chip Amps 2 24th July 2007 02:27 PM
do I need to use a heatsink on a DN2540 in a B+ supply? jarthel Tubes / Valves 1 28th September 2006 06:42 AM
Should it be enough !? Heatsink + Supply ! -_nando-_ Chip Amps 17 23rd May 2006 06:14 PM
isolating power transistor from heatsink Wagener Solid State 10 23rd May 2004 09:57 PM
Page generated in 0.08995 seconds (85.73% PHP - 14.27% MySQL) with 11 queries
