Mini-A Help Needed
Mini-A Help Needed
Old 7th May 2004, 12:15 AM   #1
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Mini-A Help Needed Send a message via Yahoo to vdi_nenna
Unhappy Mini-A Help Needed
I finished wiring up my mini-a. the voltages seemed ok, but only one channel plays loudly. By this I mean ch-1 does not produce high output. I have to put the speaker to my ear to hear anything. Ch-2 does play ok.
Could this indicate a blow or bad output MosFet?
Thanks,
Vince
CCS Ch-2
Drain= 17.27
Gate= 4.04
Source= .55
Power stage Ch-2
Drain= .01
Gate = 13.01
Source= 16.65
__________________________
CCS Ch-1
Drain = 17.15
Gate = 3.97
Source = .49
Power stage Ch-1
Drain = .08
Gate = 12.93
Source = 16.31
Old 7th May 2004, 02:04 AM   #2
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Check your feedback resistor and resistor from the - input diff pair fet to the ground. If your offset is below .5v, The outputs are likely OK.
Old 7th May 2004, 10:11 PM   #3
vdi_nenna's Avatar
I checked all the resistors in the front end and all the voltages on the current source and the input pair and they match the working side.
I'm only seeing .05 AC on the bad side and
the good side was showing 1.3 volts AC, with the CD player loudness at about 9 o'clock setting.
Also, the DC offset was about .01 on both sides.
Any other advice would be great.
Thanks,
Vince
Old 8th May 2004, 01:12 AM   #4
MikeW is offline MikeW  United States
MikeW's Avatar
Check to see if there is a short to ground at the input.
MikeW
Old 8th May 2004, 02:53 PM   #5
vdi_nenna's Avatar
No, input not going to ground either. It's clear.
Vince
Old 8th May 2004, 03:28 PM   #6
BobEllis is offline BobEllis  United States
BobEllis's Avatar
check the values of the feedback resistors and the condition of the solder joints - been there, done that.
and verify that you have a good signal going in to the "bad" channel. Done that, too. thought the amp was dead when in reality it was a bad preamp jack.
Old 9th May 2004, 07:46 PM   #7
vdi_nenna's Avatar
Default question
Could excessive solder flux cause a short? So far, this is the only possible issue I see.
Old 9th May 2004, 11:42 PM   #8
MikeW's Avatar
Check all the voltages at the input. Do Q1,2 and 3 have the same voltages as your working board. If you have a scope follow the input path until you no longer get the correct signal. I have blown up a lot of input MOSFET's.
MikeW
Old 15th May 2004, 09:12 PM   #9
vdi_nenna's Avatar
IT'S ALIVE!!!
Matched new front end fets and a new CCS and now the channel is ok!
Thing is, when I first fired it up, I saw a spark near one of the output fets. It may have been near the PS caps. I have since turned it off and on and it hasn't sparked.
Thanks everyone for your help,
Vince
Old 16th May 2004, 10:23 PM   #10
MikeW's Avatar
Default Working
How does it sound?
MikeW
Mini-A Help NeededHide this!Advertise here!
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
Helps/opinions needed before renewing my old Mini Crescendo amp Cruzs Solid State 3 15th October 2008 08:25 PM
the Very Mini Magico Mini zei Multi-Way 7 11th February 2008 08:10 PM
Copyright ©1999-2017 diyAudio
