Old 6th May 2004, 07:54 PM   #1
rif is offline rif  United States
Default Zen-light article -- error in Fig 3 or have I lost it?
Since I (and others) are using Mr. Pass' articles as an excellent learning tool, I need to know if I have this correct.
Fig 3 shows the I vs. V curve for 2 lightbulbs. They are straight lines as expected, since they are linear Ohmic devices. I'm confident I've got this part correct.
1) But shouldn't they also cross the origin if extended? From what I see, it looks like at 0 Volts, current is non-zero!
2) The article says resistance is calc'd by dividing V by I at any point. This won't work here -- I believe it should be the inverse of the derivative of the curve since the line is shifted. Change in V divided by change in I to get resistance.
So the top curve is 50 ohm, the bottom 100 ohm.
Old 6th May 2004, 08:09 PM   #2
Bill Fitzpatrick's Avatar
So where's the thing to look at?
Old 6th May 2004, 08:19 PM   #3
Details, details
http://www.passdiy.com/projects/zenlite1.htm
Old 6th May 2004, 11:34 PM   #4
The one and only
Nelson Pass's Avatar
These are the measured curves, and they are only extended
down to 40 volts. The minimum voltage shown on the scale
is 35 volts.
Filament heating increases the resistance of the light bulbs,
but the nonlinearity that results is subsonic, and the residual
audio distortion is taken out by feedback.
Old 6th May 2004, 11:52 PM   #5
Is the resistance in this linear region equal to V/I or dV/dI? I'm guessing dV/dI -- change in V divided by change in I.
Old 7th May 2004, 09:22 AM   #6
wuffwaff's Avatar
R is always V/I wich is almost the same as dV/dI if you keep the d small enough.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 7th May 2004, 04:38 PM   #7
William
The d's are for derivatives, but you probably knew that already . The values will be very different for most situations. (if y=ax+b, y/x =dy/dx only if b is zero). Ohm's Law is usually confused with V=IR if I remember correctly -- I'll look for my old univ. notes over the weekend.
I guess I just need to know if R is defined as V/I or dV/dI. Or look at it the other way: is transconductance defined as I/V or dI/dV?
Old 7th May 2004, 06:12 PM   #8
The one and only
At audio frequencies with a healthy DC voltage you can pretty
much treat it as a resistor, and you see that the 150 watt
bulb is about 80 ohms and the 300 watt bulb is about 40+.
Old 7th May 2004, 06:52 PM   #9
Thank you again!
But which is the proper way to get R? V/I or dV/dI? They give very different answers (50&100 vs. approx 40&80depending on the voltage)
Old 8th May 2004, 01:22 AM   #10
The one and only
Since you can't change individual light bulbs, you either put
up with what you've got or you parallel different types to
get what you want.
Marantz CD63 KI SIG, Error 12, Sled Error problem sisik Digital Source 1 9th November 2008 03:12 PM
I have lost my nephew...... destroyer X The Lounge 5 4th September 2006 11:37 AM
Whats worse, 1db error in response curve or a phase error of 6? primalsea Multi-Way 5 13th May 2003 01:24 AM
Page generated in 0.09520 seconds (79.65% PHP - 20.35% MySQL) with 10 queries
