Old 5th May 2004, 11:56 AM   #1
boq is offline boq  Poland
Question Question. Preamp
Hello.
I have question that probably makes most of You laugh.
What is advantage of use a preamplier (BOSOZ for example) since its output level is 2V (best sound quality). The same as directly from CD.
At input signlal is attenuated then signal is distorted and amplified to similar level.
What I get by using preamp. (except valume control ).
Old 5th May 2004, 04:52 PM   #2
Alain Dupont's Avatar
boq,
With a Bosoz or X-Bosoz even CCS-X-Bosoz you get the finest unbalanced to balanced adaptor.
You can switch between inputs, using balanced or unbalanced
You can also get a fine impedance adaptor.
And even a balanced stepped volume attenuator with 128 or 256 positions...
Perhaps a remote control for inputs and volume... + mute...
And finaly a trigger to start the class A amplifier you are listening to...
.... Otherwise you can use a dual 10 K pot right after the CD...
Regards.
Alain.
Old 5th May 2004, 10:12 PM   #3
much better sound!
Bartek
Old 6th May 2004, 06:05 AM   #4
Thanks Alain and Bartek.
My question was related to sound quality and I still don't know why preamp is better than simple potentiometer.
Wojtek
Old 6th May 2004, 06:09 AM   #5
b-square's Avatar
The #1 reason is convenience.
Alternatives to a potentiometer in a box include using a player or DAC with variable outputs or passive systems that are generally superior to potentiometers, like transformers and autoformers.
Old 6th May 2004, 06:49 AM   #6
MBK is offline MBK  Singapore
A passive colume control is fine in theory. But in many, many cases the CD output, though it has enough voltage, doesn't have enough current output capability to supply the loss through cable capacitance, attenuator and attenuator capacitance, and input impedance of the power amp. If you experiment with a breadboard, it's easy to test a simple pot against a pot with a unity gain buffer in front of it (an active preamp in other words). Whenever I did that, the dynamics improved a lot with the active stage to boost the CD output.
Many people like the fine microdynamics of passive volume controls. I suspect it's because the macrodynamics don't make it over to the power amp
Old 6th May 2004, 01:19 PM   #7
Thanks MBK for explanation.
Old 6th May 2004, 02:14 PM   #8
b-square's Avatar
I suspect you haven't heard a system with a TVC.
Old 6th May 2004, 02:32 PM   #9
Actually I haven't, and I keep an open mind. The impedance matching and CMRR (and inherent RF rejection) of a TVC is something I can see clear potential advantages from. But simple resistive passives often don't work all that well IMO. Unless the previous stage has a strong output of course.
preamp question sakis Solid State 4 17th July 2009 11:28 PM
preamp question overdrajv Tubes / Valves 7 28th December 2008 05:49 PM
Preamp Question! Lab_Rodent Solid State 9 5th December 2007 11:14 PM
X0 preamp question Tyimo Pass Labs 5 25th March 2007 08:32 AM
Preamp Question mapiao Tubes / Valves 0 6th February 2007 02:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
