I got the US model of a Pass Aleph 3 amp, and in my country the outlet voltage is 220v.
I got a 110->220 volt transformer. It's rated for 300w, while the Aleph's peak consumption is said to be 250w. Should I go with a larger transfomer? Are these known to have negative effects on sound? Thanks in advance. |
#2 |
Hello roee,
You can use 110->220 transformer without any major problems. This is exactly what I did with some of my devices that I take with me from US. However, I would rather use little larger transformer for the Aleph 3 amplifier. Around 500 VA or even higher would be much better. Best regardsn Kristijan Kljucaric |
#3 |
If it's rated for 300Watt and your amp only uses 250W max. then there is no problem using it.
Why spend money on a new transformer if you have one that works ?
#4 |
I say test run it and if it gets too hot (the step down tranny) then get a new one. if not, use it permanently.
#5 |
roee,
Look at the service manual of the Aleph 3 it's 120/240V CA compatible. You just have to modify the wiring... Regards. Alain. |
#6 |
Really great advice! Thanks all!
| 110v power amp with 220v transformer, effects sound? | Frosti | Solid State | 6 | 9th October 2009 08:49 PM |
| 110v or 220v, how can you tell? | fjmart134 | Tubes / Valves | 2 | 8th June 2009 10:18 PM |
| VELODYNE 110V to 220V | iblieve | Power Supplies | 1 | 11th May 2009 07:25 PM |
| Solid State 110V to 220V transformer affects audio? | Frosti | Solid State | 8 | 4th May 2009 07:39 AM |
| AR XA 220V to 110V | dan duette | Analogue Source | 2 | 13th February 2009 01:08 PM |
| Page generated in 0.08176 seconds (73.89% PHP - 26.11% MySQL) with 11 queries |
