Old 1st May 2004, 03:49 AM   #1
Default Aleph P hum...
Someone spared me an Aleph P board. I hooked it up w/ my parts and all points have correct voltages. However, I got a serious hum. I originally thought it might be from the ground loop, but after analyze, it was not, because the noice increase as I turn the VR up. I tried to isolate the power line, but the result is the same. Very anonying!
Any idea where may these noises came from?
I have my BZLS done last December and I don't have this problem!
Components should be OK, as I check them out. Any idea where to start debugging? (as I am IT professional)
Thomas
Old 3rd May 2004, 09:46 PM   #2
If the noise is increased when I turn the Volume up, could this be oscillation? (I never experience one, so I am not sure...)
Thomas
Old 6th May 2004, 12:50 PM   #3
As no one had replied this thread meaning that I probably is the only person have this problem....
Anyway, this is how I tried to do. I replaced the 10uF caps and it seems that the noise level have reduced a little bit, but still there. I guess different brand of cap shows different sensitivity to the noise.
With all the methods I tried to no effect, I simply just add an Input Selector board I made and the noise (or oscillation noise) is gone. I look at the Input selector board and in the signal path, it has just one 12V relay and a 221 ohm resistor in the path. (a 1uf cap and a 1n4148 diode is to protect the relay on the power side and is not in the signal path). Therefore, I guess, it removes the osillation noise by doing this. Is my guess correct?
It is quite now. (one channel still have a louder gound loop noise, but at an acceptable level, than the other, which is very quite. This is the one I will continue working on.)
Thomas
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.06309 seconds (73.22% PHP - 26.78% MySQL) with 10 queries
