One more attenuator question
Old 28th April 2004, 06:07 PM   #1
kilowattski is offline kilowattski  United States
kilowattski's Avatar
Default One more attenuator question
Gents,
A real quick question. I have the chance to get a 10Kohm 8 section attenuator on the cheap. It would be nice to use it on my Aleph 1.7 P project. What effect would the impedance mismatch have on the preamp since the preamps output impedance is 5K ohms. The input attenuation is 10K so it would work well for the input. What would happen if I only attenuated the input?
Kilowattski
Old 1st May 2004, 06:40 PM   #2
bbakota2000 is offline bbakota2000  Croatia
I'm also working on my Aleph P 1.7, and as far as I uderstood I don't have to regulate the input signal, because gain is same all the time and it's regulated with feedback resistor (2K pot or fixed resistor). I just have to put attenuator on the output signal, bacause there is no need for regulating input signal. Am I right? If I'm not please explain what did I misunderstood!
Old 2nd May 2004, 12:50 AM   #3
I am not sure either. I hope someone out there gives us some insight.
Kilowattski
Old 2nd May 2004, 09:22 AM   #4
jh6you is offline jh6you
Account Disabled
Default Re: One more attenuator question
In his Bride of Zen article, Mr Nelson Pass clarifies your question:
ˇ°Normally you see the volume control potentiometer at the input to the preamp circuit, and in this way you can insure that the input will not be overloaded. Placing the potentiometer at the output has two advantages, however, the first being that all circuit noise will be attenuated as the volume setting is reduced. Placing the volume control at the output allows the input of the gain stage to look directly at the source. This improves the bandwidth and distortion of the circuit by providing a lower RC figure for the input capacitance of the MOSFET. If you desire to place a potentiometer at the input of the circuit, feel free to do so...ˇ±
I hope this will help.
Old 2nd May 2004, 11:59 AM   #5
jh6you,
Thank you! That is exactly the information I was looking for.
Kilowattski
Old 2nd May 2004, 12:54 PM   #6
Kilowattski,
So what did you decide to do with that 10K attenuator? Where will you put it?
One more attenuator questionHide this!Advertise here!
Stepped Attenuator Question (see attached pic) LinuksGuru Solid State 0 14th December 2008 07:49 PM
YET another relay attenuator question robmil Solid State 0 14th April 2008 05:44 AM
Aikido Attenuator kit question talaerts Tubes / Valves 2 9th January 2007 10:12 PM
Stepped Attenuator Question Adam M. Chip Amps 3 3rd March 2004 08:50 AM
