( stupid ? ) idea to reduce power consumption - Page 2 - diyAudio
Old 27th April 2002, 05:04 PM   #11
Bernhard's Avatar
The bass, which is not shown on the photos is very hungry.
Are my speakers impressive ? Everything still under construction.
On top is my plasma.
The thing in the middle is a modified Infinity EMIM.
On the bottom is a very usual 6" speaker.
Old 27th April 2002, 08:13 PM   #12
PMA is offline PMA  Europe
PMA's Avatar
In case that you reduce iddle current that much, you will obtain an increase of distortion. High iddle current reduces distortion for the class A amplifier.
Old 27th April 2002, 08:39 PM   #13
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Regarding speakers, I'd say they mach amplifier.
However, with quad-amped system I'd rather go for monoblocks to avoid long cables to the speakers. But of course it all depends what you have available. Check that link: http://passdiy.com/gallery/aleph5-p1.htm
It's Aleph 5 with adjustable bias. You can also e-mail owner and ask about differences with the different settings.
Old 27th April 2002, 10:39 PM   #14
Default Nice pictures, now those 450/60 transistors
Here is the specifications for the 450 http://ec.irf.com/ec/adirect/ir?quer...lse&cmd=search
The minimum on-resistance is quite high. This in itself is not a big problem if you are using lots of them. However, this is a high voltage unit. To get desired switching characteristics, input capacitance suffers -- exacerbated by using many.
I would advise against using this unit, and I would expect the 460 to be a complete non-starter (second number usually indicates "generation" where newer is usually worse for audio). Besides, the cost of devices is low compared with total package (heatsinks, power, cabinet, connectors).
Petter
Old 27th April 2002, 10:56 PM   #15
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I think that I am over-heatsinking my aleph2. Would increasing the bias current make it sound better? How much higher can I increase it on the Aleph 2?
Brian
gte619j@prism.gatech.edu
Old 27th April 2002, 11:10 PM   #16
If you search the Forums, you should find a post that I did explaining the relationship between Aleph power and speaker impedance. This results in minimum required quiescent current and PSU voltage for a given power level at a certain impedance.
It is all pretty basic.
Petter
Old 27th April 2002, 11:13 PM   #17
Bernhard's Avatar
ok, so no 450/460.
Also my heatsinks are for TO3.
Any advice where to get suitable TO3 mosfets in Germany/Europe ?
If there is more distortion on low bias, no problem, as long as it is not getting too bad.
As background music it will be ok, and for seriously listening, I can pump up the idle ...
The Aleph5 with 6 different bias levels from the link ( isnt it a A3 ? ) is interesting...
Yes, and so, for room level, I like to reduce the idle current.
Bernhard
Old 27th April 2002, 11:57 PM   #18
Brian,
Nothing wrong with running your amp little cooler. When you'll build your amp you can play with different bias values and see how it affects sonics.
Old 28th April 2002, 12:02 AM   #19
BrianGT's Avatar
HPotter,
Thanks for your response. I was just worried that it would not run hot enough to sound good. I will play with it once I get it finished. I have my cases almost done for both channels.
Brian
Power consumption v. rms output kyrie48 Solid State 7 1st November 2008 04:41 PM
power consumption tfrei Chip Amps 2 1st December 2007 10:34 PM
A new (Stupid?) class d idea Tekko Class D 79 5th December 2006 03:01 AM
Remote Power Supply: A Stupid Idea? SRMcGee Tubes / Valves 22 29th September 2005 10:37 PM
A stupid idea DcibeL Solid State 12 2nd July 2005 03:23 PM
Copyright 1999-2017 diyAudio
