Has anybody built an Aleph-x to this spec??? - Page 6 - diyAudio
Old 24th May 2004, 05:59 PM   #51
D3 is offline D3  England
D3's Avatar
Default bleeding caps
Is it good practice to bleed the caps on switch off......what is the best state for caps to be in for longevity????
Will the Aleph-X circuit layout gradually allow a gentle discharge over time.......?????
Old 25th May 2004, 01:39 AM   #52
Brian Donaldson's Avatar
Let's not forget, this is class A and I'll bleed any amount of caps down to about 6 volts in 2 seconds. You may want to throw a 1K power resister to suck the last 6 volts over time, but the bulk drains off rather quickly.
Old 25th May 2004, 05:09 PM   #53
That's a good point.
BTW, I noticed that (at least in my A30), the plus and minus
rails drop off to different voltages. (One was a few volts
higher than the other, though I can't remember which one.)
I only bothered to measure it when I noticed that one
of the LED's stay on longer than the other one.
Dennis
Old 26th May 2004, 05:44 AM   #54
wijgers is offline wijgers  Netherlands
Default difference
I've the same with My Aleph 30. Difference in voltage of the caps after shut down.
I think that the caps at the Positive side were sightly higher than the negative caps.
Nils
Old 26th May 2004, 09:04 PM   #55
The one and only
Nelson Pass's Avatar
That difference is seen in the net current of the turn-off
thump.
Old 15th June 2004, 06:40 PM   #56
Clarkcr is offline Clarkcr  United States
Clarkcr's Avatar
Default 1000vdc Vs. 1500vdc
Why not use a bigger transformer. Don't beat me up too bad, just curious.
Chris
Old 15th June 2004, 09:20 PM   #57
The one and only
I don't think this is a transformer issue, rather the existence
of a net DC value to the turn-off thump and any potential
asymmetry in the draw between + and - supplies by the
circuit.
Old 16th June 2004, 06:31 AM   #58
D3's Avatar
Question Thump!
Hi, thanks Mr Pass for your comments.............are we talking here of a chance of getting ....... serious switch off/on thump...due to aysmitry......in discharge/charge. Or....is this likely to be a minor artifact?
Do large capacity caps make matters worse? .................
I guess it generally isn't an issue as.....I have not seen much in the way of discussion on this site........
Old 16th June 2004, 06:08 PM   #59
The one and only
It's a minor issue. The thumps that I tolerate are on the
order of a volt or so, and I haven't seen that damage even
the most sensitive drivers I've played with.
FS/FT: Fully Built Aleph-X Monoblocks [AUS] kenny12 Swap Meet 14 18th May 2009 11:03 AM
FOR SALE: Built-up Aleph 5 PCB's DirkD Swap Meet 8 25th April 2005 07:24 AM
new aleph to be built..? george a Pass Labs 10 29th August 2003 06:28 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Anyone built an Aleph L?? Mark A. Gulbrandsen Pass Labs 5 29th September 2001 05:03 AM
Copyright 1999-2017 diyAudio
