Complementary Zen- class A or AB?
Old 21st April 2004, 10:30 PM   #1
needtubes is offline needtubes  United States
Default Complementary Zen- class A or AB?
HI-
I have seen designs such as this that are labled Class AB (example, the SDS headphone amp) and then the Zen that is labled class A. Which class is this amp? Is it just a matter of bias current? What I mean is if you bias the amp at 2.2A per channel, it will run class A up to 2.2A out, then become AB for everything above. Is this remotely correct? Could this circuit be adapted for lower power (around 1W instead of 20 or so)?
Old 22nd April 2004, 12:04 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It's just the bias current.
If the amp is a push-pull type, the output current peak will
be twice the bias current, so if you bias a 1 amp, it will leave
Class A at 2 amps. Into 8 ohms, this would be I^2 * R which
is 4 * 8 = 32 watts peak, which for a sine wave is 16 watts
continuous. It will usually operate AB above these levels.
If the amp is a single-ended Class A biased by a constant current
source or an inductor, then the peak output current is equal to
the bias current, and will not deliver more.
If a push-pull Class A amp has a varying bias circuit, and there
seem to be plenty of them around, then you can set the ratios
anywhere you like, but the performance tends to suffer at
lower bias figures.
If a single-ended Class A amp has a varying current source
like an Aleph, then you can set the figures where you like, but
they are only pretty within a limited range, usually not higher
than peaks of twice the bias.
Old 22nd April 2004, 12:43 AM   #3
Thanks! That pretty much cleared everything up for me.
Complementary Zen- class A or AB?Hide this!Advertise here!
Complementary Class A Preamp using BC368-369 lineup Solid State 20 22nd September 2016 10:27 PM
Yet another complementary amp phase_accurate Solid State 3 11th May 2011 07:30 AM
How important is complementary transistor pair matching in class B amp? caesar148 Solid State 10 15th October 2004 07:06 PM
Single Vs Complementary Vs Differential Comparators in Class-D Workhorse Class D 0 27th May 2004 01:18 AM
Zen v5 non-complementary Stefano Pass Labs 15 10th August 2003 05:09 PM
