FAOW
FAOW
Old 19th July 2018, 09:40 AM   #91
Attila I is offline Attila I  Germany
Attila I's Avatar
sorry for being insensitive
A.
Old 19th July 2018, 10:09 AM   #92
juma is offline juma  Germany
juma's Avatar
Originally Posted by Vix View Post
..simple 1w amp witj Lu1014 j-fet,...
Here you are:
Q1 amplifies voltage and current (common Source mode) and Q2 is a CCS.
R5/R4 ratio sets the gain and R4 sets the Zin - don't use much higher value (up to 10k max) or you'll lose good treble. Of course, you signal/music source should be able to drive that Zin.
R6 keeps coupling cap C1 tied to GND when there is no speaker connected (to avoid panic about output DC offset).
Setting it right:
We want about 1A through JFETs (set with value of R2, start with 2R2 - lower resistance will give higher current) and about 10V (half of the V1) at the drain of Q1 (set with value of R1, start with 2R2).
If it happens that you have DC offset at input it means that your Q1 has a leaky gate but it's not a big deal, just use coupling cap at input (22u or so).
Don't forget to take good care about heatsinking Q1 and Q2 or, if you can't, lower the V1 to 15V or even 12V - it will still produce 1W at the output. If you have 16R speakers you can lower the current through Q1 and Q2.
PSRR is very good so no extra care has to be taken about power supply, simple CRC will do fine.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 19th July 2018, 11:03 AM   #93
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
FAOW
Can we do something like Figure 4 from Zen Variations#8?
Gravity - Making the G since 13.7 billion B.C.
Old 19th July 2018, 11:46 AM   #94
EUVL is offline EUVL  Europe
http://www.6moons.com/industryfeatures/zen8/11.gif
Patrick
xen-audio.com
Old 19th July 2018, 12:00 PM   #95
hates ground loops
Rodeodave's Avatar
FAOW
This is what I'm referring to:
Old 19th July 2018, 12:06 PM   #96
coolnose is offline coolnose  Europe
coolnose's Avatar
Just shout "iron" and ZM will pop up just like by miracle...
Old 19th July 2018, 06:58 PM   #97
nicoch58 is offline nicoch58  Europe
Old 19th July 2018, 06:59 PM   #98
Vix is offline Vix  Yugoslavia
Vix's Avatar
Thanks Juma.
Although I must confess that I have a fetish for lightbulbs, so I may be inclined to use one instead of the upper Jfet
Old 19th July 2018, 07:31 PM   #99
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
FAOW
A question for Nelson: if you were to build a simple 1w amp witj Lu1014 j-fet, what would you do? I am thinking of something extremely simple, just for fun, something along the lines of Zen V8, but without the cascode, and maybe with a lightbulb
Will it work, or will it Pop?
The problem with the Lu1014 is that I have not had good success making
it behave itself outside of a cascoded situation, and stopped trying after
a while.
But seeing as I have about 7000 of them, maybe I should take another
look.
Old 19th July 2018, 08:38 PM   #100
I saw a German SRPP quite some years ago using a pair of LU1014 on 18V rails.
Could not find it anymore.
There is a Chinese website posting something similar.
But I could not recall whether the two are identical or not.
http://f1.hifidiy.net/forum/forumid_...dd3fe97d50.jpg
Patrick
xen-audio.com
FAOWHide this!Advertise here!
