Caps for a Not-So-Bright Idea
Old 7th July 2018, 03:44 AM   #1
Skip Pack is offline Skip Pack  United States
Default Caps for a Not-So-Bright Idea
I have Altec 605B's in open baffles above 18" woofers in open-backed (big) boxes. Works pretty well. But there are always wrinkles. I use simple passive line-level cap-resistor bypass with series resistor shelving filter to correct some of the OB cancellation, but there are other FR wrinkles to deal with.
I chased a reference to the section of the liked page with the "Have Ya Ever Been Too High???". Do It Yourself DIY
It has five parallel shelving filters evenly spaced. It might work for me.
I thought it could be useful to put a switch on each filter so they each can be switched out of the circuit. I also thought that adding one more parallel leg at a lower frequency cold be helpful in my OB case.
My question for now is 'What do you suggest for a series of capacitors that would be matching/compatible in character over the range of values: .001uf, .002mf, .0047uf, .01uf, .022uf and .047uf?'
That range seems to demand one type of cap (film/film and foil) for the larger values and something else (silver mica?) for the smaller ones. Needing 12 caps, I dpn't want to spend a lot of money on these, at least until I've had a chance to listen to the results of an initial build. Any suggestions here?
Thanks, Skip
Old 7th July 2018, 08:45 AM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
just use proper industrial quality
I personally prefer Polycarbonate (MKC) , but there is - frankly- decision in same amount as actual preference based on listening
that way I sleep better and think less
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th July 2018, 09:24 AM   #3
Attila I is offline Attila I  Germany
Attila I's Avatar
@Skip Pack
since you might want both sides as close as possible use vishay 1837 mkp. these are 1%
A.
Old 7th July 2018, 04:34 PM   #4
Thank you both! Checking out the MKCs and the 1837s online, I see no values below .01uf. What other type of cap would be good for .001-.0047ufd? As an aside, I'm surprised that the small value Roederstein/ERO and Wima MKC caps are not as expensive as I thought they might be.
Skip
Old 7th July 2018, 05:02 PM   #5
tomchr is offline tomchr  Canada
tomchr's Avatar
There are plenty of ceramic options in the 1 pF - 100 nF range. Just pick one with an NP0/C0G dielectric.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 7th July 2018, 05:11 PM   #6
Zen Mod's Avatar
for these - if not (selected) silver mica , I;m simply using biggest SMD I can find
if I need through hole , I just solder tiny wires on them
Old 8th July 2018, 03:37 AM   #7
Once again, Thanks. I'm thinking that capacitance meter my be in my near future. Will an inexpensive unit that covers a good range be adequate for selecting the closest match from handful of caps?
Skip
Old 8th July 2018, 07:32 AM   #8
Zen Mod's Avatar
it depends of your luck
some are cheap and good , some are drek
Old 8th July 2018, 04:07 PM   #9
Worth a try. I can test the same group of caps multiple times over several days to see how consistent he results are. It's consistency rather than accuracy that would seem to matter here.Thanks again.
Old 8th July 2018, 09:30 PM   #10
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
Originally Posted by Skip Pack View Post
...What other type of cap would be good for .001-.0047ufd?
Skip
WIMA FKP2. I like to use them for the values that are too large for silver mica (FKP2 are available from 33 pF on) up to a few nF. When I can't get the value I'm looking for in FKP2, I try to move to WIMA MKP10.
You can get the FKP2's in 2.5% rated tolerance.
Best regards,
Claas
Caps for a Not-So-Bright IdeaHide this!Advertise here!
Hybrid bright idea Stee Solid State 0 2nd August 2011 04:38 PM
replacing 47mf for 33mf caps...good idea grahamfocal Digital Source 8 27th April 2011 06:10 PM
motor run caps in the output? good or bad idea? jarthel Tubes / Valves 36 1st November 2006 06:47 PM
