Audio Design Guide 2014 Power Follower
Old 20th June 2018, 01:53 PM   #1
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Audio Design Guide 2014 Power Follower Send a message via Yahoo to vdi_nenna
Default Audio Design Guide 2014 Power Follower
I posted this in Solid State Forum first, but after 150 views, no one has any idea, so I'm requesting help from the might Pass Labs forum. Also, I directly emailed and contacted the author on one of his threads regarding this very design, but no answer.
It's a MOSFET Power Follower so it's not alien to the PL guys here.
So, any help or advise would be appreciated.
Original post:
I have some questions about the Andrea Ciuffoli 2014 Power Follower.
The new 2014 schematic and 2014 board do not include the output cap.
Is the output section built the same way as the older schematic?
I assume the positive speaker connection, if built like the '99 version, connects to the positive side of the output cap. This correct?
Is the 1k resistor needed across the speaker on the 2014 version
The 2014 schematic shows R10 and R11. Are both needed?
The '99 Power Follower Schematic is not label with a date. The 2014 schematic is labeled.
Thanks,
Vince
I build, therefore I am.
Old 20th June 2018, 03:02 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Iq 3A??
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th June 2018, 03:08 PM   #3
vdi_nenna's Avatar
Is this a rhetorical question or are you concerned by it being too much?
New version is fixed by R1. Old version can be switched.
That's what the man said. Is that too much?
Is it any crazier than 2.5A for the MoFo? I don't know. MoFo sounds great at 2.5A
Old 20th June 2018, 04:02 PM   #4
indra1 is online now indra1  Indonesia
Originally Posted by vdi_nenna View Post
... any help ...
Is the output section built the same way as the older schematic? Yes, but no provision to alter bias.
I assume the positive speaker connection, if built like the '99 version, connects to the positive side of the output cap. This correct? Depends on what you want. I think there should be no problem to connect Negative polarity of speaker to positive leg of output cap if you prefer negative H2 phase.
Is the 1k resistor needed across the speaker on the 2014 version. Yes, to avoid unwanted dc potential build up on output terminal due to output capacitor.
The 2014 schematic shows R10 and R11. Are both needed? No, choose one.
Old 20th June 2018, 04:04 PM   #5
Zen Mod's Avatar
too much
two trimpots on schematic - just provison to mount two different physical styles - see pcb - mount one you prefer to fiddle with
resistor across speaker is bleeder - to drain outout cap and prevent plop! when connecting speaker
output node is at negative potential , ref. to gnd , so output cap must have negative pole at output node , positive to speaker
edit: indra was faster
Old 20th June 2018, 04:14 PM   #6
vdi_nenna's Avatar
Thank you both! Much appreciated!
Old 20th June 2018, 04:27 PM   #7
vdi_nenna's Avatar
E/I = R, so .7v/2.3A= .304 R
Could take the current down with a .3 Ohm 3w resistor.
Old 20th June 2018, 04:46 PM   #8
Zen Mod's Avatar
I prefer MoFo .....
certainly livelier , due to principle
Old 20th June 2018, 05:40 PM   #9
vdi_nenna's Avatar
Originally Posted by Zen Mod View Post
I prefer MoFo .....
You built both or you just looking at the schematics?
Not worried because only paid for the boards. Rest of parts and case are spares. Got an $100 gift card at work and used Amazon to buy the rest I didn't have.
Not afraid to give this interesting circuit a try.
How many power amps can be built with one small filter cap?
I have no idea how it will sound. Just interested in Power Follower sound right now. Maybe I'll dump this one and build a couple of F4 monos and live happily ever after. who knows
Thanks for the help!
Vince
Old 20th June 2018, 05:58 PM   #10
vdi_nenna's Avatar
BTW, there's also this power supply version.
Audio Design Guide 2014 Power FollowerHide this!Advertise here!
Audio Design Guide 2014 Power Follower vdi_nenna Solid State 0 19th June 2018 02:04 PM
Fall 2014 NorCal DIY Audio Group MTG: SAT, OCT 25 CharlieLaub Clubs & Events 21 2nd November 2014 12:22 PM
2014 california audio show vkung Elekit 2 30th August 2014 04:07 PM
Commercial Audio Brands: N-Ch/NPN only output devices in a push pull power follower tiefbassuebertr Solid State 0 11th May 2011 10:15 AM
Audio Design Guide Devil_H@ck Solid State 7 13th February 2004 01:18 PM
