My first Pass Labs clone: Aleph (X)Ono(-ish) phone stage
Ono: PCB layout
Here is my PCB layout
Voltage Regulator
Salas Shunt Regulator (v1.2R) producing +- 30V DC. I incorporated the K(Keantoken's)-Multiplier into the PCB, but somehow, the latter didn't work well, so I by-passed the K-Multiplier and directly connected the input of Salas Shunt Regulator to the unregulated DC coming from my filter bank, which is housed in a separated casing along with the toroidal transformer
Unregulated DC power bank
This is the PCB of the unregulated DC power bank for both L + R channels. I'm using MUR820 diodes as rectifiers and Kendeil K05 electrolytic caps.
Can I use SUT with XOno?
I would like to experiment a bit with an MC step-up transformer. Is it possible to use MC cartridge + SUT + XOno? I assume that I should hook the SUT output to the MC input of XOno? Or is it a very bad idea....
I'm thinking of hooking MC cart + SUT to XOno MM input, but cannot change the resistive loading with XOno MM input....
