Aleph3 clone offset problem
Old 10th June 2018, 03:25 PM   #11
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
btw. I hope all testing and setting is conducted with outputs properly on heatsink .... so that picture is taken prior to proper mounting
just in case ......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 10th June 2018, 04:47 PM   #12
prakarn is offline prakarn  Thailand
Hi Zen mod , The pot was set at 220 at starting point then trying to decreases R108 lower than 390R as you suggested.
mpmarino :they have insulator pad, do not touch each other. The good channel has be good since first SW on , without any VR to adjust. I just decided to add when fixing the bad one.
I believe heat sink is big enough.
File Type: jpg 34875760_1813185842082294_4938326269927358464_n.jpg (96.2 KB, 152 views)
Old 10th June 2018, 06:31 PM   #13
Zen Mod's Avatar
tripple check all resistor values , orientation of parts etc.
maybe is wise to replace input mosfets ....... in case you succeeded in zapping them
Old 11th June 2018, 03:01 AM   #14
These input fet is second set actually. At First set, I got about 1.2V, cannot remember plus or minus, then reload second magazine and installed two VRs and get -3.7V. Ödo not know what to do next ......
I may take some parts out for check and re solder all joints again. Do you think where be a possibly bug area? I really hate to take part out /in through hole pcb.
Old 11th June 2018, 06:16 AM   #15
Zen Mod's Avatar
when all parts are by prescription , with just two trimpots you must be able to set everything
positions are R108 , R113 , while everything else as shown on schematic , fixed values parts
leave it for few days , unburden your head , then be back with fresh energy
for starters just compare visually all parts between channels
Old 11th June 2018, 07:56 AM   #16
Not ...with Magnifier Ha ha....I will tell you some good news next week.
Thank a lot Zen MOD.
Old 16th June 2018, 10:01 AM   #17
I changed the parts as you told on both channels. The situation are still same.
When turn the new POT 500R at R108 the DC offset can not be lower than -2.5V then fluctuate , LED dim down.
I reckon it might be have some malfunction or dead part there.
All compared voltage seem be okay except at the Q103 drain leg . It is about 6.7V but the work channel is only 3.5V.
What I should do next? thank you
Old 16th June 2018, 04:49 PM   #18
Zen Mod's Avatar
voltages across Z103,R106 , R108 and across source resistors of outputs ?
Old 17th June 2018, 01:26 AM   #19
I measured after 10 min SW ON.
To give you more information , at Z103 be paralleled with 2.2 uf film capacitor and changed R105 from 4.75K to 3.3K as papa recommended on both channels.
Old 17th June 2018, 07:50 AM   #20
Zen Mod's Avatar
-if input mosfets are OK,
-if there is no some wrong resistor value,
you must be able to set DC outout offset varying R108 ; in this case you need to decrease it's value (lower bank of mosfets opened too much)
with inputs shorted and no load ........ use multiturn trimpot for R108 , if you don't have steady hand , needed for single turn trimpots
Aleph3 clone offset problemHide this!Advertise here!
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
My Aleph3/5-BA-2-Semisouth-J2 Clone Monster generg Pass Labs 106 19th January 2011 07:25 PM
Is this DC offset problem. rs1026 Chip Amps 4 24th December 2004 12:02 AM
Aleph3 problem rtirion Pass Labs 30 1st April 2002 09:56 PM
Aleph3 voltage problem kasra Pass Labs 12 20th November 2001 08:24 PM
