a suitable transistor substitution for Delite amp
Old 31st May 2018, 01:15 AM   #11
Pascal Nguyen is offline Pascal Nguyen  Australia
Originally Posted by gmurray618 View Post
I do have a heat sink question.
My CPU heatsink copper plates had a poor surface finition, means poor heat transfers.
I treated them with my elbow grease (wet sand paper).
Extra measure has to be taken for active cooling system, an NC thermostat (a dollar or so) in series with the PSU in case of malfunctioning or forgot to turn fan on.
Cheers
File Type: jpeg C68B06EE-E5E3-4415-8BE2-3A697C151465.jpeg (955.2 KB, 215 views)
Old 31st May 2018, 04:41 PM   #12
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Use some goop with them.
Old 2nd June 2018, 10:08 AM   #13
It would be fine for your environment, I suppose.
Mine, I do wet sanding daily, as Karaté Kid had to, with a purpose to have a Popeye arm.
Cheers and thanks for your kindness
File Type: jpg A35F3D34-9D47-4AC3-B742-BD26A37AC8A0.jpg (771.6 KB, 143 views)
Old 2nd June 2018, 05:12 PM   #14
gmurray618 is offline gmurray618  United States
Very cool. I like the idea of repurposing the old computers. This week I’ll check out the voltage coming out of the PC power supplies (not the 19.5V laptop bricks - the internal power supply). It wouldn’t be the worst thing to have to rectify and smooth + and - 20 to 30 volts like I did with the F5. It would jacknthe price up to have to get the transformers and caps but good lessons.
As for goop I’m going to try and save their little hands and use thermal insulation pads, similar to the ones in the ACA kit. CD-02-05-190 Wakefield-Vette | Mouser
Thanks for the help and encouragement. Right now I’m thinking having my class creat accounts here and post progress on a class thread. If I get jammed up I know there is a wealth of knowledge here.
George
Old 3rd June 2018, 10:16 AM   #15
WalterW is offline WalterW  Netherlands
It doesn't look very well sanded?
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 3rd June 2018, 01:53 PM   #16
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
An internal ATX-type computer power supply won't do it. 12V max, and the corresponding -12V is only good for an amp or so. The +12V output is pretty stout. You could run a handful car audio-type chip amps with it for a few watts of output each.
They do make for a quick and greasy benchtop supply with (IIRC) +12V, -12V, +5V,-5V, +3.3V available.
Tim
Old 3rd June 2018, 03:15 PM   #17
Thanks Tim (by the way, love your avatar). I’ll think of something else to do with them and plan on swing a proper transformer I suppose. So far administration is behind me on this project. Fingers crossed.
Old 5th June 2018, 09:32 PM   #18
So I was looking at transformers (100 VA 20V) to get +/-28 V, so I’ve got 56V to power the amp. So I run close to 1A through the light bulb that acts as a 40-50ohm resistor to bring the voltage about 12V to feed the collector. (Do I have it right so far?)
So my question is why not ditch the light bulb and use a 12V supply? (Yeah, I know the light looks cool �� but it’s a more expensive transformer)
Old 5th June 2018, 10:20 PM   #19
aspringv is online now aspringv  Australia
The light is acting as a constant current source (ish) to the transistor. The transistor is creating the voltage output across that resistor...
Old 5th June 2018, 10:31 PM   #20
woody is offline woody
In this amplifier the voltage across that transistor is only 12v if no signal is being amplified. But when you are amplifying a signal the voltage across the transistor is changing perhaps from 2v to 30v . That light bulb just acting as a big resistor allows
for this voltage swing across the transistor. Without this swing there would be no ac
output that is NO music .
a suitable transistor substitution for Delite ampHide this!Advertise here!
Transistor substitution bolly Parts 2 16th January 2018 12:44 AM
Need Help With Transistor Substitution McInRantz Solid State 9 8th February 2016 09:51 AM
mps6566 transistor substitution dcassyc1 Solid State 5 23rd February 2010 06:15 PM
transistor substitution help needed! Thanks crippledchicken Parts 18 4th July 2008 12:08 PM
Transistor Substitution hewlew1 Solid State 82 4th September 2007 02:49 AM
