My old Aleph 4 clone
Old 13th May 2018, 10:39 AM   #11
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I was thinking about testing the caps with a 470R 5W resistor in series with the existing transformer and diode. I'll check the diodes and the transformer beforehand.
I'd expect good caps to charge to about 35V (70% of Vcc) in about 15 seconds.
Is there a better way of testing them ??
Old 14th May 2018, 12:06 AM   #12
Eric is offline Eric  United States
Eric's Avatar
Caps will have to be removed from the circuit for testing. Your proposed method of charging them should work well. What might be revealing is to see how long they hold the charge you give them. Charge them up, let them sit for a while (few hours?), then measure their voltage to see where they are. I suspect you'll have one or more that will be completely discharged in relatively short order. The faster they discharge, the worse they are.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 14th May 2018, 03:24 AM   #13
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Eric View Post
... ...The faster they discharge, the worse they are.
True; but fast discharge would not blow a fuse.
A fuse-blowing fault would be *instant* discharge; or inability to get a charge at all.
Old 14th May 2018, 06:09 AM   #14
Sorry, I didn't make it clear that they would be individually tested out of circuit.
Old 16th May 2018, 12:26 PM   #15
Eric's Avatar
True. I was trying to think of a good way to identify a bad cap with minimal equipment. Probably the best way I can think of is to test caps one at a time, directly connected to the power supply as usual, with a "dim bulb tester" in series with the transofrmer primary. When the light doesn't go out, you've found the bad cap. If one is bad and they are all from the same lot, the others are likely to expire soon as well.
Old 16th May 2018, 02:27 PM   #16
woofertester is offline woofertester  United States
Attached is a link to a video of how to test a capacitor ESR with a scope and a function generator.
YouTube
at 10:15 how shows a bad capacitor
Old 16th May 2018, 05:56 PM   #17
Eric's Avatar
Great video- thanks for the link!
Old 16th May 2018, 09:12 PM   #18
PJN is offline PJN  United States
Maybe disconnect the psus from the amps and see if the short is in the psus or amp boards. Might shorten the search.
My old Aleph 4 cloneHide this!Advertise here!
(one more) ALEPH P 1.7 clone veteran Group Buys 1095 6th May 2018 06:48 AM
FS : Aleph P 1.7 clone sernikus Swap Meet 1 11th April 2008 04:14 PM
