Thanks Nelson
Thanks Nelson
Old 14th April 2018, 11:24 PM   #1
nzlowie is offline nzlowie  Australia
Default Thanks Nelson
Hi Nelson
I know you're a very busy man and won't have time to answer lots of msg's so I understand if you just take the thanks part of this message!
First of all, I like countless others offer thanks and gratitude for the unselfish work you do for the diy audio community, too many times we see people with your skills just take and take, for me this is refreshing so thanks for being you.
I've just been watching a couple of your video seminars and realized you must have tried hundreds of amp configurations...... I've made a few amps over the years that have been in the diy arena, even though I could probably afford some of the really good gear I enjoy building and trying to optimize my system.
My current system uses 4 ACA's driven with minidsp for my mid/hf horns, a DSP bass amp drives the bass. I think it was zenmod who suggested I could replace the output caps for something better than electrolytic as we only needed FR down to 500hz, this improved things further.
Now comes the questions.....
I know the ACA was meant as a starter project, do you have any better designs you could share in the <5w range? My horn's are around 115db so very little power required.
I'd also like to replace the minidsp with your new xover, I realize it won't have DSP capability but will there be any way to tweak the FR for a non linear driver? Or in your opinion is it better to leave a few peaks and dips rather than eq the hell out of the signal? I like the minimalist approach, the less we interfere the better right?
Sorry msg got a bit longer than planned! Anyway keep up the good work we appreciate your support.
Regards Dave
Old 15th April 2018, 06:05 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Thanks Nelson
Flattery will get you anywhere.....
Perhaps a nice single-ended version of a follower? Very easy to do.
Maybe ZM or Mike will put one up.
The first crossover coming does have EQ on top and bottom, as it was set
up for the LXmini. On the top, there is a notch to take out a peak in the
driver, and on the bottom there is boost at the lowest frequency, and
both of these are variable with choice of resistors and capacitors. This
one has fixed values, but I will have another one which is variable,
pretty much delivering the performance of the B5.
Old 15th April 2018, 06:12 PM   #3
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Thanks Nelson
look no further than Mr. MR's MoFo
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th April 2018, 06:25 PM   #4
woofertester is offline woofertester  United States
This was the answer to my question the other day.
Old 15th April 2018, 07:07 PM   #5
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Thanks Nelson
Wow! With that sort of efficiency, you could get away with a 12V MoFo, maybe even battery powered. With a nice tube pre, Bob's your uncle.
Visit AudioMaker.Tech
Old 15th April 2018, 07:16 PM   #6
Zen Mod's Avatar
Thanks Nelson
as I said , look no further
Old 15th April 2018, 07:22 PM   #7
Vix is offline Vix  Yugoslavia
Vix's Avatar
Or, try F2 lite. Just like an ordinary F2, just replace the CSS withh the lightbulbs. With 19v or 24 v supply, maybe you could get a 2-3 w one. Super simple, has some gain, and it has magic
And yes, thank you Nelson for all amps and bright ideas
Old 15th April 2018, 07:37 PM   #8
AudioMaker.Tech
Thanks Nelson
Old 15th April 2018, 07:52 PM   #9
Zen Mod's Avatar
Thanks Nelson
for bass duty , increase C1 to 10mF
for squawker duty , leave it as is ..... or use adequately calculated solid cap
Old 15th April 2018, 11:53 PM   #10
Nothing wrong with giving credit or thanks where it's due. Too many of us just take without giving a thought to the work that happens in the background. This goes for many aspects of life.
Ok, will keep watching with interest.
Cheers
Thanks NelsonHide this!Advertise here!
Papa Nelson Big Mu Amp Rembulan Pass Labs 3 28th November 2014 11:50 PM
Half-Nelson Amp wrenchone Pass Labs 36 25th September 2011 07:54 AM
Thank you Nelson kilowattski Pass Labs 19 28th July 2008 03:20 AM
Thanks Nelson tedr Pass Labs 1 18th January 2008 06:15 PM
Nelson Stefano Pass Labs 28 9th May 2003 05:32 AM
