ACA V1.5 Illustrated Build Guide
Old 19th June 2018, 04:20 AM   #381
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by freejazz00 View Post
Also, I believe that right speaker output wire should be in the left (red) post.
Nope.
In order to be bridged the speaker has to be attached to both channel’s outputs, one of them running backwards... the red posts are not the outputs, but ground, so if you did that, you’d be using only one channel, and get standard power to the speaker, not the additional power from bridging.
Old 28th July 2018, 04:51 PM   #382
olderthandirt is offline olderthandirt  United States
Default ACA 2U mini dissipante layout
6L6 Thanks for this awesome build thread! Hopefully this is not off topic. But my daughter and I are building a non ACA undrilled standard chassis for this project. We would like to drill and tap prior to the parts kit arrival. We want to complete the amp before she goes back to school. Does anyone have a back panel layout with dimensions or the 2U UMS pattern for the heat sinks?
Kevin
Old 29th July 2018, 06:06 PM   #383
Default Has anyone received their ACA Chassis?
I am hoping someone who has received the ACA chassis would verify some dimensions. Here are our rear panel hole diameter estimations. And have enclosed rough sketches of the distance measurements needed. Thanks for your help.
Hole Diameter
Neutrik 15/16”
Speaker post 7/16
RCA post 3/8
On/off switch ¼
Power plug 7/16
LED ?
Old 10th August 2018, 12:54 AM   #384
73 and a 3rd is offline 73 and a 3rd  United States
Not sure if this is the right place to ask but could someone please direct me to a bill of materials for the 1.6 kit? I don't understand why this does not come with it. I am trying to verify my kit complete before beginning my build. Thanks in advance!
Old 10th August 2018, 11:15 AM   #385
I found this on page 3. Also you can use the schematic.
It appears that everyone is using the original ACA thread for the 1.6 build.
Originally Posted by exw9 View Post
awesome, thanks! i also made this table, maybe it will also be helpful:
R2 .47 3W
R3 .68 3W
R4 .68 3W
R5 100
R6 100
R7 10k
R8 1K
R9 1K
R10 332K
R11 10K
R12 39.2K
R13 10k
R14 1K
R15 2.21k
C1 3300
C2 1000
C3 10
C4 10
Q1 IRFP240
Q2 IRFP240
Q3 ZTX450
Q4 2SK170
P1 5K
Old 10th August 2018, 11:48 AM   #386
Quick and dirty BOM. Hopefully no errors.
R1-R11 and R13-15 (2)
R12 (3)
C1-C4 (2)
Q1-Q4(2)
P1 (2)
ACA V1.5 Illustrated Build GuideHide this!Advertise here!
F5Turbo Illustrated Build Guide 6L6 Pass Labs 458 7th August 2018 10:13 AM
F6 Illustrated Build Guide 6L6 Pass Labs 1187 3rd August 2018 02:17 AM
Aleph J illustrated build guide 6L6 Pass Labs 2706 31st July 2018 11:03 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 149 18th July 2018 07:45 PM
ACA illustrated build guide 6L6 Pass Labs 142 10th July 2018 11:14 PM
